Is the profec specII that bad?
Old Apr 30, 2004 | 02:56 PM
7'sfalife's Avatar
How many FC's are using this controller and is it really that bad? I just bought one and am wondering If I should return it are not!
Take a look at this https://www.rx7club.com/showthread.p...hreadid=292114
Old Apr 30, 2004 | 07:06 PM
7'sfalife's Avatar
Old Apr 30, 2004 | 07:13 PM
BDoty311's Avatar
88 AE
My AE used to have one, but the previous owner advised me to remove it due to the accuracy of it. He said it could a psi or two off, which isn't good for a highly moddified TII. I cannot say i have any bad experiences with it, but the previous owner, who knows his ****, advised me to sell it and get a MBC.
Old Apr 30, 2004 | 08:43 PM
7'sfalife's Avatar
I have noticed mine to be about 2psi off but I leave myself that margin for error!
Old May 1, 2004 | 09:53 AM
7'sfalife's Avatar
but I think that it has something to do with the in line filter going to the controller.
Old May 1, 2004 | 12:42 PM
7'sfalife's Avatar
^ Anybody?
Old May 1, 2004 | 05:46 PM
7'sfalife's Avatar
Anyone else have any bad experiences with the specII?
Old May 1, 2004 | 05:56 PM
eViLRotor's Avatar
Brother of the Rotary
I'll let you know as soon as I install mine...probably next week.
I have read all its supposed problems, but I also know people who have no issues, and it works great
Its certaily a little bit more involved to set up than the original...
Old May 1, 2004 | 09:14 PM
7'sfalife's Avatar
well I got mine in and it seems to be working fine so far but it is tricky getting it set up as for as the settings!
Old May 2, 2004 | 11:31 AM
7'sfalife's Avatar
What setting is everyone ruNning on the specII?
Old May 2, 2004 | 01:01 PM
carx7's Avatar
I have to say that anybody who knows what they are talking about would not recommend a manual boost controller over an EBC. EBC's are much better, whether is a Profec or someother other controller. At least get the origional Profec B if you don't want the spec II. An electronic controller will build boost faster and should maintain it more accurately.
As for the Spec II, I have not yet had any problems with mine. it seems to be working great if i'm running 1bar or 1.3. FWIW, I have a .7 bar spring.
-Chris
Old May 2, 2004 | 02:48 PM
fcfdfan's Avatar
Reverse Engineer
I took off all the Greddy Profecc and Rebic boost and injector controls off my TII because it was worthless **** that promoted detonation. Greddy stuff sucks ***, if you ask me. I wasted big $$$ on that crap.
Old May 2, 2004 | 04:29 PM
dag's Avatar
dag
No, bad tuning sucks ***, I've seen multiple cars with just such a setup that run just fine.
Old May 2, 2004 | 06:11 PM
7'sfalife's Avatar
I like the specII so far just wondering what everyone elses settings are!
Old May 2, 2004 | 06:43 PM
piston's Avatar
I have a Specll on my 87 tll and it works great if you set it up right. I will admit that tuning it is hard but once you have it set right its solid.
Old May 2, 2004 | 06:47 PM
Scott 89t2's Avatar
SOLD THE RX-7!
if it's a psi or 2 off it's because it's reading turbo outlet pressure and not TB pressure which will be different.... your boost gauge will read TB pressure which will be lower. unless the controller has a line to the TB to read boost. in which case ignore...
Old May 2, 2004 | 07:59 PM
NZConvertible's Avatar
I'm a boost creep...
Yeah, that was a bad bit of advice.
I can almost guarantee that nearly all problems with electronic boost controllers on FC's is actually caused by the controller trying in vain to deal with boost creep. Unless you have rock-solid control of your boost without a controller, you'll never have proper boost control with one.
All an EBC does is delay the opening of the wastegate and then regulate the flap position to keep boost where you set it. it cannot increase wastegate flow, so if the wastegate's fully open and it can't flow any more, your expensive controller is basically useless.
Old May 2, 2004 | 08:06 PM
eViLRotor's Avatar
Where is the best nipple to take the pressure source from that goes into the NC port on the solenoid?
Old May 2, 2004 | 08:17 PM
EBC's don't read boost pressure at the turbo, they have a separate pressure sensor that should be connected to a post-TB nipple or teed into a post-TB line (MAP sensor, BOV). The solenoid valve gets connected to the turbo and wastegate.
Old May 2, 2004 | 11:25 PM
shiftnmadkwik's Avatar
SUPERnaturally Aspirated
there was a good boost controller comparisson in SCC and i found it online
http://www.sportcompactcarweb.com/te..._boostcontrol/
Old May 3, 2004 | 12:02 AM
7'sfalife's Avatar
Can you just T it in with the boost guage line you already have run through the fire wall? At least I do because of my boost gauge. Is this wrong? In the instructions that came with the specII it said to T into the fuel pressure regulator! What up with that should I!
Old May 3, 2004 | 02:48 AM
Yes, that'll be okay.
They say that because on piston engines the FPR line is easy to identify and access. That's not true for 13BT's. It doesn't matter which line you tee into, as long as it's fed from after the throttle.
That's not too good England...
Old May 3, 2004 | 09:37 AM
carx7's Avatar
I'm thinking that i fed off the middle nipple on the front side of the UIM by the TB... there is a row of three there and I think that middle one is the one that everyone should use... but I'll have to re look at my car tonight... that detail seems to be slipping my mind right now.
-Chris
Old May 3, 2004 | 10:53 AM
eViLRotor's Avatar
-Chris
Thanks.
Just FYI, it was planning on Teeing it off my BOV line:
Old May 3, 2004 | 11:42 AM
carx7's Avatar
Actually, the BOV line is probably the worst line to use. The valve can cause flutter in the reading and cause seemingly erratic problems. The FPR and boost gauge/ controller should be off the same port.
The BOV should have a port of it's own.
