HKS cast manifold with T04B
Old Nov 3, 2001 | 10:56 PM
fcturbo2's Avatar
I have a T04B that will be going in once the new motor is assembled. With the HKS cast exaust manifold will the T04B clear the lower intake manifold??...
Anybody here have the same set-up??..
Old Nov 3, 2001 | 11:10 PM
Scott 89t2's Avatar
SOLD THE RX-7!
the hks manifold sticks way out. i'll clear the intake but it might hit the frame rail. my friend had to put a dent in his rail to make it fit
Old Nov 3, 2001 | 11:22 PM
fcturbo2's Avatar
Yeah i was told that i will run into fitting problem but wasnt sure if it was the lower manifold or the frame rail. Now that i know its the frame rail, what will be the best way to dent the rail????..
Do i just bang it with a hammer??..
Any suggestions???
Old Nov 3, 2001 | 11:53 PM
Scott 89t2's Avatar
SOLD THE RX-7!
his is a full TO4, I think the "B" is smaller so you might not have a problem. if you do I would guess heat it up really hot with a torch then start to bang.
Old Nov 4, 2001 | 12:12 AM
InitialD FC's Avatar
The T04B is a full T04, the B is a slightly less efficient housing than the E. The reason your friend had to bang his frame rail is because of the on-center exhaust housing, which you dont want to run in the first place, a tangential housing will clear both the frame rail and the intake manifold, that is if your running under a 1.32, but if you have an on-center style housing, send it back now before you use it, get a tangential, it fits better and flows better.
Old Nov 4, 2001 | 12:25 AM
RX-7 GT's Avatar
HyperREV.com
yo, scott i read your guy's site...nice cars that is pretty gay about hammering the rail. sort of bad for your car's structural integrity but oh well
Old Nov 4, 2001 | 02:15 AM
fcturbo2's Avatar
[QUOTE]Originally posted by InitialD FC
The T04B is a full T04, the B is a slightly less efficient housing than the E. The reason your friend had to bang his frame rail is because of the on-center exhaust housing, which you dont want to run in the first place, a tangential housing will clear both the frame rail and the intake manifold, that is if your running under a 1.32, but if you have an on-center style housing, send it back now before you use it, get a tangential, it fits better and flows better. [/QUO
**sigh*** Its sucks that i have to hear that because i have the same turbo. Its a Garrett T04B .60 V-trim .96 P-trim. Its an On-center style housing and its undivided. Im not seeking for high horsepower 7. All i want is better than stock.
Does anybody have any problem with my turbo???..
Old Nov 4, 2001 | 09:37 PM
fcturbo2's Avatar
Turblown
Mar 21, 2018 11:19 AM
befarrer
Sep 4, 2015 08:26 PM
