timing problem
Old Apr 28, 2004 | 02:13 PM
rotorysuzuki's Avatar
the rxzero
timing problem
I am tring to get this thing running and now I am real stummped been messing with the timing and when I set leading yellow to pin and try trail it reads same as lead no matter what I do whats up with that if I move trailing it moves leading and it runs but breaks up around 5000 rpm
Old Apr 28, 2004 | 02:30 PM
gsl-se addict's Avatar
Super Moderator
What kind of timing light is it? Sometimes the inductive style will pick up the leading ignition even when it is clamped onto the trailing lead. If it is an inductive light, try connecting it as close to the distributor cap as possible on the T1 lead.
Old Apr 28, 2004 | 02:37 PM
the rxzero
yeah it is the one that goes around the wire I will try that right now
Old Apr 28, 2004 | 02:47 PM
the rxzero
that didnt help anything what else could it be
Old Apr 28, 2004 | 03:11 PM
813KR$'s Avatar
TEAM MAZDA
Is your vac advance disconnected?
If so, try setting your timing while idle is a 4,000 rpms, then check?
Old Apr 28, 2004 | 03:19 PM
the rxzero
no do i have to disconnect the vac
Old Apr 28, 2004 | 04:34 PM
the rxzero
tried it that way and it didnt help still messed up
Old Apr 28, 2004 | 05:35 PM
rototiller1's Avatar
Inspector, Falcon Jet
the ignitors use a single wire for the ground, check the wiring diagram, I had the same thing happening so I changed this so each ignitor was completely wired separately
Old Apr 28, 2004 | 06:14 PM
REVHED's Avatar
Hunting Skylines
You must have read the diagram wrong because the ignitors do not use the same ground wire. Each of the coils has a seperate wire running from the negative terminal to it's respective ignitor. The ignitor simply acts as a switch in the coils primary circuit by interrupting the current path to ground. The ignitor itself is grounded through the body of the distributor.
Old Apr 28, 2004 | 06:19 PM
What ever! I can see a common wire between the ignitors,
Old Apr 28, 2004 | 06:34 PM
REVHED's Avatar
Hunting Skylines
That's because the circuit is completed through the back of the ignitors to the distributor/engine block which is obviously common. The actual WIRES already run seperately from each of the coils to it's respective ignitor.
Old Apr 28, 2004 | 06:40 PM
then I had a bad ignitor, but wiring them completely seporate, fixed my problem, the same problem rotarysuzuki is having, I have since went direct fire
Old Apr 28, 2004 | 06:47 PM
Rx7carl's Avatar
Airflow is my life
Re: timing problem
Get a new light. Some lights just arent compatible. My cheapie walmart special works great. My $$ sun light does what yours does. Go figure.
Old Apr 28, 2004 | 06:48 PM
the rxzero
I had them grounded together and had a bad igniter fixed all that but still breaks up when I shift hard to 2 gear
Queppa
Nov 18, 2024 03:47 AM
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
alphawolff
Nov 17, 2015 05:57 PM
