Shifter Issue
Old Apr 23, 2004 | 07:33 PM
cpa7man's Avatar
Racing is life!
Shifter Issue
I have an 84 SCCA ITA car. The shifter shifts ok, but I find I miss the 2 to 3 shift and sometimes instead of going into 4th it wants to go back into 2nd. Shifter feel is very vauge.
The question is, (before I take everything apart) do any of you have any idea what might be wrong? Could it be as simple as a shifter bushing? Or worn linkage?
Any ideas would be helpful. Thanks in advance.
Paul
Old Apr 23, 2004 | 09:40 PM
Jeff20B's Avatar
Lapping = Fapping
It could be. You could also try a torque brace.
Old Apr 24, 2004 | 02:15 PM
RX-187's Avatar
live fast. die fun.
I notice that sometimes I can't shift into 3rd gear when I shift quickly. Where can I get a torque brace for my FB?
Old Apr 24, 2004 | 02:40 PM
Second2none's Avatar
racingbeat.com
Old Apr 24, 2004 | 02:45 PM
Junia's Avatar
Uchinanchu
Would stiffer tranny mounts help
Old Apr 24, 2004 | 03:06 PM
crazysuprakid's Avatar
Well I pulled the troubleshooting guide, this is what is says.
Probable cause:
Bent change rod
No grease in trans controll system
Insufficient oil
Derioration of oil quality
Wear or play of shift fork or shift rod
Wear of synchronizer ring
Wear of Synchronizer ring and cone of gear ????
Excessive longitudinal play of gears
Wear of bearing
Wear of Syncronizer key spring
Improper disengagement of clutch
Well I hope it's not internal to the transmission. I'm going to tear into it tomorow.
Paul
opps: wrong login
Old Apr 24, 2004 | 03:08 PM
I don't think I can run a torque brace in SCCA ITA class.
rgordon1979
40
Mar 15, 2022 12:04 PM
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
