N/A to T2, fuel pump rewire, please help?
Old Apr 19, 2004 | 11:18 AM
-=Lil Red=-'s Avatar
R.I.P. Guitarjunkie28
i have an 87 N/A, im doing the T2 swap and i want to rewire the walbro fuel pump.
i have the 2 resistor/relay from the stock T2, but where is the one on my N/A? i have read the instructions how to wire it, but where is my stock N/A fuel pump relay? do i have to cut it and use the 2 new ones? or leave it alone, i dotn even know whre it is?
is it by the passenger side head light cover?
Old Apr 19, 2004 | 09:16 PM
nodbody can help me ?
Old Apr 20, 2004 | 03:01 PM
faster7's Avatar
I'd be skipping the TII fuel pump wiring install altogether if you're wanting a "rewired" setup feeding the wallbro.
Run a healthy 10-12ish gauge fused power lead back to the strut tower or under a storage bin. Put a good ~15A-25A relay there, triggered by the stock fuel pump wire. Run new power to fuel pump from the relay. I'd tie the stock fuel pump ground wire to a good chassis ground, and come off that same ground for the new fuel pump ground.
Old Apr 20, 2004 | 11:36 PM
is there a way u can draw a diagram of how i can wire all of this please? thanks so much.
Old Sep 3, 2004 | 02:22 AM
cezonetheillest's Avatar
https://www.rx7club.com/attachment.p...achmentid=67856
rewire diagram
check this out also
https://www.rx7club.com/showthread.p...=tII+fuel+pump
