whats the best elect fan to use short 81-82 radiators
Old Apr 19, 2004 | 10:16 AM
TOYOROTOR's Avatar
which fan could i use on the early 81-82 short radiators
need electric fan or fans to bolt right up..."space is limited cause of intercooler"
Old Apr 19, 2004 | 10:37 AM
Bolox's Avatar
aparently the efan of an old tauros (sp?) is basicly a straight bolt (zip tie ) on...
-Cheers
Old Apr 19, 2004 | 11:52 AM
85rotarypower's Avatar
love the braaaap
I hear that the old taurus and fiero fans work. I do know that an old escort fan will work. Thats what I am using of course. You should be able to just use some long zip ties to attach it.
Old Apr 19, 2004 | 01:20 PM
Xavier8's Avatar
Never satisfied
Its some bank but a flex-a-lite 310 fan twin line fits perfectly, and pulls 2100 cfm. Also comes with an adjustable thermostat. When I say perfect, I mean, perfect. Even has weatherstripping to make sure all air is pulled from the rad and not from outside it.
Old Apr 21, 2004 | 10:07 AM
TOYOROTOR's Avatar
what year taurus???
Old Apr 22, 2004 | 09:07 AM
surfpac's Avatar
Early 90's 3.8 V6. I got the same one from a Lincoln. I got the relay as well from here.
http://www.partsamerica.com/PartDeta...pe=600&PTSet=A
Old Apr 22, 2004 | 09:09 AM
surfpac's Avatar
I think this continuous duty solenoid would work as a cheaper alternative to switching on that high amperage fan.
http://www.partsamerica.com/PartDeta...pe=575&PTSet=A
Old Apr 22, 2004 | 09:10 AM
surfpac's Avatar
Toyorotor,
I got the fan from the U-Pick in Davie for $26 (including warranty).
Old Apr 22, 2004 | 09:53 AM
TOYOROTOR's Avatar
surfpac
what year lincoln and what model did you get the fan off
Old Apr 22, 2004 | 10:24 AM
I have a lincoln 3.8l fan that is exactly like the 3.8l taurus 3.8l fan except it is hispeed only. The taurus fans have 2 speed fans but we can only wire them up for either hi or low speed anyway.
I'll sell it to you. I couldn't get it to fit my 1980 and I didn't want to remove my AC stuff or relocate my radiator.
PM me if you are interested.
Old Apr 22, 2004 | 01:06 PM
TOYOROTOR's Avatar
Rutnick
if it didnt fit your 80 it probably wont fit my 80 radiator which is mounted in a 73 corolla, i have less space than most people.... i thought the 3.8l fan was very thin....
Old Apr 22, 2004 | 03:20 PM
surfpac's Avatar
Are you sure about that. The Lincoln I got it from has the dual speed fan. (3 wires coming from it, 1 ground, 1 low speed, 1 high speed).
Old Apr 22, 2004 | 03:23 PM
surfpac's Avatar
I The taurus fans have 2 speed fans but we can only wire them up for either hi or low speed anyway.
I'm wiring mine up for 2 speeds. I'm doing the wiring diagrams and when I actually do it I'll post pics, wiring diagram, components and cost.
