1997 RX7 type RS Single Turbo problems
Old Apr 18, 2004 | 10:33 PM
philkeoghan's Avatar
Hi I have the following set up
13B Single Turbo conversion td66 Trust Greedy Turbo, 45mm External Wastegate, Front Mount intercooler, Emissions controls removed (pluged up), not sure on the injectors I think they have been upgraded, with 3 Bar map sensor and HKS Fcon (piggy bac computer) the car seem to use a hell of a lot of fuel and not produce a whole lot of power has anybody had this sort of problem, then sometimes it goes really good for a bit like it's suposed to.
Any help or guides on what to look out for would be really appreciated also you can ask me questions about it to give you more infor thats all I can think of at the moment.
Cheers
Phil
www.rotors.co.nz
phil@rotors.co.nz
Old Apr 19, 2004 | 09:11 AM
FC Alex's Avatar
Go and get it tuned.
If you have bigger injectors, and the car hasn't been tuned that's a problem. I don't know much about HKS piggy backs. But good luck on finding someone to tune it.
Old Apr 19, 2004 | 11:22 AM
Wargasm's Avatar
Weird Cat Man
Yeah I agree... sounds like the car needs a few hours spent with a wideband oxygen sensor. I don't know how adjustable the HKS FCON is... so you might have a problem there.
Old Apr 20, 2004 | 05:20 AM
I just put some injector cleaner in it and it seems to be getting better and better not sure though the car might be just having one of it's good days, will take it in to get tuned
Also what is a safe boost pressure for a TD66 turbo?
Old Apr 20, 2004 | 09:09 PM
fc1jz's Avatar
Fecal Matter
Don't waste your time tuning that. Sell it, and get a Power FC then tune it. The fcon is decent when using stock twins, ecu, injectors. But when you start going beyond that, such as larger injectors and full single conversion, you need the pfc to tune timing, fuel and such. You can only trick the stock ecu so much. Not speaking from experience (yet) but I have read 4 billion posts about this same subject since I too have pieced together a single kit with no instructions.
Good luck to you!
sherff
Feb 24, 2019 12:09 PM
