Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D Pressure source for MAP sensor
Old Apr 18, 2004 | 10:58 AM
eViLRotor's Avatar
Brother of the Rotary
Right now, I'm getting my pressure for the internal MAP sensor on my v3.1 from where the BAC used to be (see pic).
Is there a getter place to get the signal from?
Old Apr 18, 2004 | 07:57 PM
Well you want your map to read exactley your motor is seeing, so you want to take reference as close to the block as possible.
There is the stock nipple that points towards the fire wall, on on the inside of the manifold for the fpr and now the one you've created. I'd say any would do, but if it'd make you feel better you could swap nipples (sounds kinky) with the one below it. I'd say theoretically that's the "best".
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
