Anyone slipping AN OS twin ?
Old Apr 18, 2004 | 07:11 AM
Marcel Burkett's Avatar
Question Anyone slipping AN OS twin ?
Yep , its slipping the God Damn clutch AGAIN...... , after all my previous clutch problems I aquired a slightly used OS clutch , I had to resurface it , the machinist only taking off .002" though . I bought brand new discs and plates for it , installed everything and now it slipping when I am in second gear from about 6000k rpm (when the bridges get pumpin) and still at only 10psi of boost !!!! and rich a/f ratioc ( i have to retune after the '044 installations). Seems like I wo'nt ever get to tune to 20 +psi of boost.
Old Apr 18, 2004 | 10:55 AM
XSTransAm's Avatar
Ee / Cpe
wish i had your problem
Old Apr 18, 2004 | 11:11 AM
SPOautos's Avatar
Hey, where did my $$$ go?
You have a dyno sheet? How much tq are your making? How much is that OS supposed to hold?
Are you daily driving it and slipping it at take off? That going cause it to "glaze" over and start slipping. Most of the high performance clutches are designed to be droped at take off instead of sliped from a red light, ect. Could that be the cause?
You might try a SPEC clutch, they have a new street clutch that will hold 550lbs of tq and being a street clutch you can pull away from a redlight without dumping it
STEPHEN
Old Apr 18, 2004 | 02:37 PM
IRPerformance's Avatar
Sponsor
Best clutch I've driven on was an Exedy twin disk I installed in a customer's car. Very smooth takeup, almost like stock. Its rated to 700 hp. If you need more, there is a triple disk available. I've also driven on a Spec cluch and its a pain in the *** around town. Almost as bad as a 6 puck.
Old Apr 18, 2004 | 05:04 PM
SPOautos's Avatar
Which Spec clutch were you you driveing? I've got a 4 puck from them that feels like the stocker and has held up for 10K miles so far on my car with no sign of wear. I'm making 350rwtq and over 400rwhp and drive the **** out of it eveywhere. Its supposed to be good for around 450tq or so but like I said they have a new on thats supposed to be good up to 550 and Dave (works at Spec) said it'll feel about like my current clutch
I would like some more info on the Exedy though. How much do they cost?
STEPHEN
Old Apr 18, 2004 | 05:28 PM
BoostdFC3S's Avatar
im gonna side with spo a friend of mine has a spec stage five. I beleve its an iron disk! Of course thats a bit over kill but still not enough for anger manegment.
Old Apr 18, 2004 | 06:29 PM
Sponsor
Not sure. Wasn't a puck style disk, had a full face. The engagement in this particular car is really harsh.
Old Apr 18, 2004 | 09:12 PM
RETed's Avatar
Get a carbon one...
-Ted
Old Apr 19, 2004 | 08:49 AM
spoolin's Avatar
THATS MY CAR HE'S TALKIN ABOUT!!
Old Apr 19, 2004 | 05:08 PM
SPOautos's Avatar
spoolin - Is yours the Exedy or the Spec? If its the Spec which stage is it? Also, when bolted to the flywheel what was it tqed to?
STEPHEN
Old Apr 19, 2004 | 07:25 PM
spoolin's Avatar
they just installed the exedy last week
Old Apr 19, 2004 | 08:28 PM
shawnk's Avatar
Perpetual Rebuilder
Doesnt the twin disk have a ridiculously long break-in period? Like 1000 city miles or something? How long have you had it?
Shawn
Oh - and make sure and drop me a note if you end up selling that piece of crap .
Old Apr 20, 2004 | 01:37 AM
Sponsor
I've never really broken in any clutch I've had. I just go easy for 20 or so starts to bed in the material. I never understood why people put a milage number on cluthc break in. The clutch isn't being abraded when you are driving, unless you are shifting. The exedy felt fine from the moment I backed it out if the shop.
Old Apr 20, 2004 | 06:31 PM
Turns out that I had the actuating rod on the clutch slave cylinder adjusted too far out so the clutch was slightly depressed . After looking I found that there is a big leak on the master cylinder so there wasn't complete disegagement when the pedal was depressed , making me keep moving the adjustment out until it was at max.I did find it strange since it came off another 3rd gen but it wasnt working on mine.
So I readjusted it and there is no slippage anymore , I also have to replace both clutch cylinders.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
