Clutch Choice
Old Apr 17, 2004 | 11:04 AM
seadog34's Avatar
Clutch Choice
My 82 rx is modded up pretty well now but experiencing clutch slippage around 6k rpm. Anyone got a good clutch combo recommendation. Most of the time is street driving and stock not cutting it. Also want to do some road racing....
Old Apr 17, 2004 | 11:32 AM
mazdaverx713b's Avatar
Have RX-7, will restore
i would go with a centerforce stage II
Old Apr 17, 2004 | 03:03 PM
elwood's Avatar
I like the RB Street & Strip setup with the lightweight steel flywheel. Seems reasonably durable (I've had two of them -- on a FB tranny and now on an FC T2 tranny) and gives a nice boost in throttle response due to the lower inertia.
Don't like Centerforce. The idea of hanging weights of the clutch diaphragm springs that create more clamp load as RPMs increase was developed for muscle cars with high torque engines to keep clutch pedal pressure in check. Pedal pressure isn't an issue with rotary engines (since they don't have much torque), so I'd avoid the potential failures caused by extra parts.
Old Apr 17, 2004 | 04:35 PM
hornbm's Avatar
FD > FB > FC
yeah but have you ever heard of the centerforce pressure plates failing? I sure havent.
Old Apr 18, 2004 | 08:06 PM
act stage 2 is what i have
Old Apr 18, 2004 | 08:18 PM
YapaKanichi's Avatar
Smile Like a Donut
I'm having that problem kind of, like in 5th gear just cruising at 60 or so if I floor it the rpms race and drop then the car speeds up.
Old Apr 18, 2004 | 08:41 PM
CODE BLUE 2's Avatar
Resident Bitch
Light fly wheel and a center force #2.
I had bought my car 4 years ago with a Center force and it finally went out about a week ago. I put another one in the car. There are a few good ones but I like how Center force has treated me. As I at times have not treated it nicely.
Ian_D
Oct 14, 2015 12:31 PM
risingsunroof82
Sep 9, 2015 08:06 PM
