Ground Control Spring set?
Old Oct 31, 2001 | 04:56 PM
Ryde _Or_Die's Avatar
I saw a car with these and was wondering how difficult it is to put these on your car. Would you need to take it to a shop to do this? If so how much would they charge? I know my friend has put his own springs in 2 or 3 cars but these look a little different. Thanks.
Old Oct 31, 2001 | 04:59 PM
O ya, how adjustable is the drop? Thanks alot.
Old Nov 1, 2001 | 08:26 AM
Old Nov 1, 2001 | 09:26 AM
David88vert's Avatar
r71's daddy
Which set? Are you talking about the regular spring set or the GC coilover kit?
Old Nov 1, 2001 | 09:34 AM
The set I saw online was for adjustable spring sets. They used eibachs(sp?) and you just lifted the corner you wanted adjusted and turned the threaded piece. They were $399 for 4. I will get the site when I get home and post it. Thanks.
Old Nov 1, 2001 | 10:41 AM
Racer 13B's Avatar
I have the Ground Control set up on my FC.
Its not that hard to install them. (IMO)
I still have the Ground control insruction sheet. I could take a photo of it and e-mail at to you. So you can get a better idea of you'll need to do. I don't have a scaner.
thanks
scott
Old Nov 1, 2001 | 11:00 AM
r71's daddy
The 2nd gens are much easier to install than the 1st gens. I have them on my FB and they were a lot of work. We put them on an FC and it was much easier. The camber kit is nice to have with them though.
Old Nov 1, 2001 | 01:54 PM
SpeedRacer's Avatar
Formula Mazda Driver
thanks
scott
Hey, could you email me those pics? I got a used GC set and put it on myself, it was pretty easy and straightforward, but I didn't have instructions so it took me a little more time than it should have. I just would like to see the instructions for peace of mind. I posted in the suspension forum a few weeks ago asking if somebody could take pics and send them to me, but nobody replied.
The only place I ran into problems, was lack of spring compressor, and lack of impact gun. But I got around them. If you don't have a spring compressor, you can use bailing wire and wrap it throught the spring coils, and use a screw driver to twist the wire to tighten it. Thats what I did to get keep the springs from flying out. Also the top nut that holds the top of the strut is a bitch without an impact gun. You can try to use a screwdriver and wedge it between the bolts on top of the strut mount to keep the assemble from twisting while you get the center nut off. I ended up taking the assmembly to my uncles house and using his impact gun. Hopefully for Christmas I'll get my own. Anyways, other than that, everything went pretty smooth. Oh, I had to use a grinder on the strut casing thing to make the threaded collar fit over it. I don't know if others had to do that or what. I had stock struts. But anyways, if you give yourself a better part of a day, you can probably do it, if you have a socket set, various screwdrivers, and maybe an impact driver. It took me about 4 hours, and I had no previous experience doing suspension work. You should probably upgrade your struts at the same time. I wish I would have, stock struts won't handle stiff springs very well, especially old worn out struts.
The kit allows me to stay anywhere from stock height, to a 2" drop. I'm quite happy with it. I have had mine at 2" drop since its been installed. I have stock rims though so it doesn't look THAT lowered. Occasionally a passenger will scrap my door on a curb and I'll have to bitch at them, and you there is NO curb you can clear with the front end.
