Sponsored by: CARiD
water temp gauge
Old Oct 31, 2001 | 02:25 PM
Gab88na's Avatar
water temp gauge
where is the sender for the water temp gauge????
is it the thing at left of the oil pressure????
where can i connect and aftermarket temp gauge??
in that little hole??
thanks guys
Old Nov 1, 2001 | 09:07 PM
Marine7599's Avatar
I installed an Autometer mechnical water temp gauge. I used the 6 or 5 FT?? long wire guage. Some people said only the longer wire gauge works but you can make the shorter one work I installed the gauge where the radios go with two other gauges. I ran the wire towards the glovebox and through the firewall there. I put the temp sensor on the side of the water pump housing. There is already a spot for it by just unscrewing the plug. There may be trouble fitting the sensor there if the smog pump is still being used. I had to adapt a special adapter to install it there but it can be done. The gauge helps a lot.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
mulcryant
Sep 9, 2015 05:24 PM
dillrx7
Sep 7, 2015 09:38 AM
