79 intake ?
Old Apr 12, 2004 | 02:25 PM
rotorysuzuki's Avatar
the rxzero
79 intake ?
I am putting my truck back together and my sterling carb should be here soon my ? is when iI put the 79 intake it leaves a slot open under it between the header and intake how do i plug it or should I just use my 83 intake with out the shutter valve in it
Old Apr 12, 2004 | 02:46 PM
I have always wondered about that myself..
A 79 intake should povide a cooler intake charge since there is no exaust air warming the incooming air.
Old Apr 13, 2004 | 08:55 AM
the rxzero
but can I plug that slot or what carb should be here soon and I need to get it ready so I can go smoke some v8 jeeps yehaw
Old Apr 13, 2004 | 08:58 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
You have to make a plate that covers it.
Old Apr 13, 2004 | 09:03 AM
the rxzero
how do I fasten the plate
Old Apr 13, 2004 | 09:09 AM
Sterling's Avatar
You have to machine a plate ressembling a gasket. It must be rather thick.
We will be offering these later this season.
Old Apr 13, 2004 | 09:17 AM
the rxzero
okay I understand now I do have an 83 intake with shutter removed dont feel like fabbing anything did enough in this truck already plus I want to do dlidfs soon thanks
Old Apr 13, 2004 | 11:06 AM
Rx7carl's Avatar
Airflow is my life
You can also bolt a piece of angle to the manifold to block it.
Old Apr 13, 2004 | 11:12 AM
rxtasy3's Avatar
u can also get those blocking nozzles, i think that's what they're called, that require removing the oil pan to replace. RB sells them. i have them in my '74 engine. then u wont need the plate.
Old Apr 13, 2004 | 11:30 AM
Rx7carl's Avatar
Airflow is my life
I dont think that will work on a 83-85. Different setup on the housings. You can block the passage, but the engine should be apart to do it.
