How to break the steering lock
Old Apr 11, 2004 | 10:10 PM
Cyrio's Avatar
Question How to break the steering lock
Fellow 7's
I bought a motor and tranny off a guy in an Ebay auction. The only problem is the motor and tranny are still in his car(which does not run). This car was his parts car. After trying to figure out a good time for us to meet to take it out, we determined that I would just take the whole car home and take the motor and tranny out myself when I get time. Well I go to pick up the car and he tells me that hes lost the key and the steering wheel is locked. We had to get the car into the trailer with a forklift. The only problem is, I dont have a forklift at my house. Anyways, to make a long story short, the car is stuck at my house and I can't get it into the garage because of my driveway setup. The guy told me to go ahead and break the lock because hes does not care about it anymore anyways. Does anyone know how to break it so I can steer the car?
Chris
SCCA Pro7 #20
Old Apr 11, 2004 | 10:14 PM
85rotarypower's Avatar
love the braaaap
You should be able to remove the steering wheel and get at the lock that way to somehow disengage it. I don't know how to do that, but you should be able to do something if you remove the steering wheel.
Old Apr 11, 2004 | 11:36 PM
capri93's Avatar
The thing
Grabe hold of the wheel and use muscle thats how i did it.
Old Apr 12, 2004 | 12:26 AM
Siraniko's Avatar
RX for fun
Remove the entire ignition lock!!..remove the steering wheel surround panel, then chisel out the bolt that holds the lock assembly. If you need more room, remove the bolts that holds the steering shaft.
Old Apr 12, 2004 | 12:28 AM
kettlman's Avatar
THE ONE. THE ONLY!
get a strong flat screwdriver bit, puond it in the lock with a hammer, hook a 1/4" socket on a ratchet and turn. should break it free.
Old Apr 12, 2004 | 12:34 AM
rxtasy3's Avatar
or just remove the key cylinder, there's a small set screw on the under side, loosen this screw and the cylinder will pull out then turn that piece inside there with a pair of needle nose pliers.
Old Apr 12, 2004 | 01:42 AM
web777's Avatar
Car thief!!
Old Apr 12, 2004 | 01:43 AM
web777's Avatar
dp
Old Apr 12, 2004 | 01:53 AM
O 16581 72452 5's Avatar
The infamous number guy!
Like said before, just turn the wheel as hard as possible, it'll break.
Old Apr 12, 2004 | 08:30 AM
wwilliam54's Avatar
it WILL run
under the dash there are 2 bolts that hold the steering coloumn up un bolt thgem and twiste the colum around till the wheel is upside down, the lock will stay fallen out
Old Apr 12, 2004 | 08:32 AM
Siraniko's Avatar
RX for fun
Originally posted by web777
Car thief!!
car thief = using dent puller...
Old Apr 12, 2004 | 10:59 AM
GOOFYROTOR's Avatar
cams pistons valves
very good wacko. you were taught well!
Frox
Sep 8, 2015 08:36 AM
TwentyDW
Sep 2, 2015 06:42 PM
