Water pump leak
Old Apr 10, 2004 | 07:14 PM
capri93's Avatar
The thing
Water pump leak
I ripped the water pump off the 7 today found out where it leaks there are two small holes near the shaft they look like the might have been freeze out plugs, am i correct in this thinking and if so can they be repluged.
Old Apr 10, 2004 | 08:20 PM
Rx7carl's Avatar
Airflow is my life
Huh? The only freeze plugs are in the iron housings. Where are these holes exactly that you speak of?
Old Apr 10, 2004 | 11:42 PM
capri93's Avatar
The thing
The holes are in the front plate of the housing where the shaft runis through they are on the top and bottom of the housing nearer the base of the shaft.'
Old Apr 11, 2004 | 01:00 AM
Jeff20B's Avatar
Lapping = Fapping
Weep holes.
Old Apr 11, 2004 | 01:19 AM
capri93's Avatar
The thing
????? weep hell they poor water out the one is like .25"the water runns out as fast as i put it in.
Old Apr 11, 2004 | 01:35 AM
rhinor61's Avatar
Yeap weep holes, the reason they are pouring water out is cause the shaft seal is bad.
DO THIS AT YOU OWN RISK>
Old timer trick would be to add 2 tablespoons for brake fluid to cooland. This will cause the water pump seal to swell up.
Or, just replace the water pump.
John
Old Apr 11, 2004 | 04:29 AM
1984se's Avatar
Ryan
Originally posted by Jeff20B
Weep holes.
someones been reading the manual...
have the same problem also...except its leaking from the very bottom bolt the one that actually a BOLT and not a NUT...
BTW, does anyone know if that bolt should have a lock washer or regular washer?
Removed it and just added a thin but good coat of silicone to try to seal it...no good still leaked. From the same area that the bolt was located.
Also, when you spin the pump is it supposed to "Spin Freely" like spin it and it keeps going or just spin and not hard "Resistance".
BACK TO THE TOPIC-
Just replace it .
-Ryan
Old Apr 11, 2004 | 02:30 PM
I know that this is sort or off topic, but
When I replaced my water pump I found that it was incredibly hard to take off (because of the two additional pulleys for the ac and ps). It took about 20 minutes just to take it off.
Old Apr 11, 2004 | 04:12 PM
1984se's Avatar
Ryan
yeah you kinda gotta "pry" it off the pulley, but not hard at all....just enough to get it past the pulley... one good tap should do the trick too..
-Ryan
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
rotor_veux
Sep 3, 2015 07:10 PM
