Sponsored by: CARiD
Bearing sound(sounds like a tweeety bird in my engine)
Old Apr 6, 2004 | 01:28 AM
ROTARise's Avatar
ok ever since i let my dumbass cousin drive my car around this nieghboorhood i was letting him go to shop nearby(john's body shop and deatiling) then as we came up on the stores garage door theres a hill going upwards so he stalls on the hill or whateveer then i start hearing this noise coming from the wheels (front) sounds squeaky as if a bird tweets....its annoying what could it be?
thanks a bunch
Old Apr 6, 2004 | 08:38 AM
Cosmo Donk's Avatar
Queer
Probably dirt stuck under the brake pad. Does it make it all the time?
Old Sep 20, 2012 | 12:13 PM
88GTU_AutoX's Avatar
I'M BRINGING THIS THREAD
BACK FROM THE DEAD!!!
I've got an 88 GTU, fyi, and very clean.
I'm bring it back mostly because I have the same issue as above, only on both sides. Can't tell if it's the bearings, the pads, the rotors...???
I'll turn right at 25 mph, I get jingling, or chirping, from one side. I turn to the other, it happens again. when I'm headed straight and it isn't jingling, I press slightly on the brakes and it starts up again. Foot off of the brakes, it stops. At higher speeds it is pretty much a constant. Much lower and it doesn't happen at all.
Any ideas? Experience?
Thanks! Zack
Old Sep 21, 2012 | 12:49 PM
farberio's Avatar
NASA-MW ST4
Probably wheel bearings. Lift up the front of the car and grab the tires at the 3 and 9 position and move the wheel around. If the wheel moves around then the wheel bearing is bad.
But don't confuse movement with the steering rack movement.
Old Sep 22, 2012 | 08:38 AM
Thanks. I'll get it up and test it soon.
ppritchard
Interior / Exterior / Audio
Aug 21, 2015 06:02 PM
elfking
Aug 19, 2015 09:48 PM
rx7jocke
Aug 15, 2015 03:36 PM
befarrer
Aug 14, 2015 04:18 PM
WyomingTII
Aug 13, 2015 10:42 AM
