Sponsored by: CARiD
Throwout bearing
Old Apr 3, 2004 | 08:09 PM
Bowdowntome's Avatar
Throwout bearing
I just changed my clutch pressure plate and t/o bearing. It is still whining. Im pretty sure it isnt the syncros because it stops when I push in the clutch. Does the t/o bearing need to break in? Or does anyone know why it is still doing this?
Old Apr 4, 2004 | 06:31 AM
rgordon1979's Avatar
LS what?
Did you apply a little grease to the t/o bearing when you installed it. Also, is it a stock Mazda t/o bearing. I have heard you should ONLY use the stock bearing. Unless the whining is overbearingly loud, I would not worry about it. Mine whines a little bit all the time, stops when I push the clutch in too.
Old Apr 4, 2004 | 09:19 AM
rxtasy3's Avatar
have u ever thought it might be the bearings in the tranny, after all, everything stops turning when u push in the clutch.
ls1swap
Jun 3, 2024 03:25 PM
Vartok
16
Oct 8, 2015 04:49 PM
