start up problems
Old Oct 29, 2001 | 09:25 PM
picassotrigger's Avatar
Newbie
Question start up problems
Hey guy's, what's up. I'm new to this board. I've got one question. I just bought a 1985 RX-7 and I'm having problems starting the car. Every time I try to crank the car it doesn't start and doesn't turn over. Does this mean that my starter is bad? Anyway, I'm new to carbs and rotoraries. If it is my starter can anyone give me instructions on how to replace the starter. Any help will be greatly appreciated.
Old Oct 29, 2001 | 09:59 PM
rx7passion's Avatar
does the starter click or it does nothing at all.. can you compression start the car?
Old Oct 30, 2001 | 06:54 AM
jimmyv13's Avatar
Round&Round not Up&Down
Ride your bike to the auto parts store and get a Haynes manual.
Old Oct 30, 2001 | 02:46 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
*Fully* charge the battery, that could likely be the problem. If it still doesn't work, clean all the connections on the starter. Particularly the little slide-on solenoid connector, it always gets dirty. Make sure all the wires are in good shape.
You could also try hotwiring the car to see if the ignition switch is the culprit. Check the Hayne's manual for wiring diagram.
If that doesn't do the trick, the starter is very easy to replace, just 2 bolts into the tranny. Get it tested first though, no sense replacing something that isn't bad.
It's my experience that most 'starter' problems are solved by charging/replacing the battery and cleaning all connections.
Oh, and as mentioned before, get a Haynes Manual, you'll need it.
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
