factory alarm
Old Oct 29, 2001 | 01:37 PM
kev's Avatar
kev
factory alarm
I have an 88 turbo 2 annivarsary edition. I have the factory alarm system on it and it doesn't work now. You know when you open your door with the car turned of and the key in the ignition, and it makes a beeping noise? Well, my car makes that beep all the time, even when the key isn't int the ignition. I figure this has something to do with my alarm not working. If any of you know how to fix this please let me know. Thanks.
-kev
Old Oct 30, 2001 | 12:27 PM
Tohru's Avatar
Yokohoma--->So Cal
hmmm
on my 10th ae, it makes that beeping sound when i lock the door when its opened, without the key inside, then u close whiel holding the handle upwards, but that's about it, maybe ur doing that? heh
Old Oct 30, 2001 | 06:10 PM
kev's Avatar
kev
no dude, I'm not talking about the beep that the alarm itself makes, i know what your talking about there. I'm talking about the beep that the steering column makes when you open your door with the key in the ignition.
Old Oct 31, 2001 | 10:50 AM
Icemark's Avatar
You have a bad key sense switch in the steering column.
Sometimes the plug/switch just get unlocked from the housing, pull the steering column cover and look at the small off white colored two wire plug on the underside of the key switch location. Make sure it is up tight into the bottom of the key switch.
Turblown
Sep 30, 2015 05:58 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
