What does the air pipe to the pre-monolith converter do
Old Mar 29, 2004 | 06:20 PM
BrewerBob's Avatar
I luv sheep&dead hookers
The air pipe to the pre-monolith converter broke loose. I'm reading from the FSM and it's the only thing I can find that looks similar. Do I need it? I'm guessing this is just more emmissions crap that I can live without.
I've been meaning to drop the cat and clean its innards out. I live in SC so I don't have to worry about a smog check.
Old Mar 29, 2004 | 06:45 PM
ChasRX's Avatar
I believe it is to add air (oxygen) to the chamber to after-burn the emissions, moreso.
Old Mar 30, 2004 | 10:28 AM
BrewerBob's Avatar
And why can't it add air without the pipe? Unless you are running thru water, it will get air all by itself with just a hole.
Well, I guess it's 1/2 a pound lighter now!!
Old Mar 30, 2004 | 10:32 AM
anthrax's Avatar
Heck Yes!
It is used to bring air into the cats at low RPM in an attempt to generate lower emissions levels at lower RPMs
Old Mar 31, 2004 | 05:28 PM
peejay's Avatar
Old [Sch|F]ool
But mr. bob, you want air injected only *sometimes*. Air at the wrong time can result in increased emissions, from too lean of an exhaust mixture going to the main cat.
Queppa
Nov 18, 2024 03:47 AM
