my tach on my 81
Old Mar 28, 2004 | 10:12 PM
nopistons94's Avatar
white FD lover
my tach on my 81
hey guys, just bought a 81 and the tach doesn't work. Not to up on the FBs but i want to start getting into them more so sorry if its a stupid question but, what should i be looking for to fix the tach. The speedo DOES work so it has to just be the cable i think. thanks for the help
joe
Old Mar 28, 2004 | 10:39 PM
white FD lover
Old Mar 29, 2004 | 12:43 AM
rick-l's Avatar
That's usually a sign your trailing ingnitor is TU.
Old Mar 29, 2004 | 12:44 AM
Siraniko's Avatar
RX for fun
easiest is to check for unplug wire in the trailing coil...I cant remember if its the green or blue tab. check the diagram in the repair manual.
Old Mar 29, 2004 | 09:01 PM
white FD lover
alright sounds good, anyone know where i can get a repair manual online at ? i know some internet sites just have them so you can browse through them. thanks
Old Mar 29, 2004 | 09:36 PM
white FD lover
damnit i want my stupid tach to work man lol
Old Mar 29, 2004 | 11:18 PM
exodus82's Avatar
somebody on here can scan a page and post it so he can test it.
Old Mar 29, 2004 | 11:24 PM
enigma32's Avatar
I would but I don't have a scanner....
Just buy the Haynes manual :-)
Old Mar 30, 2004 | 12:34 PM
white FD lover
ya if anyone could just give me a brief discription on where to locate the cable. Sorry for being so ignorant on the topic, however im use to my FD problems, and i've never had a problem with my tach on either car. Thanks guys
-Joe
Old Mar 30, 2004 | 12:59 PM
n8r's Avatar
n8r
I just delt with this issue and it's one of two things.
Your Ignition Coil or your Ignitor, the ignitor can be had pretty cheaply from the Parts section on the forums here, you don't wanna buy one new since they are $150 at least.
The easiest way to test your coil is to run your car and CAREFULLY pull the wire that runs from your coil to the distributor. FYI it's an easy way to shock yourself, but that's the fastest way to check it.
Most likely you will only have spark running on your Leading 2 spark plugs, the trailing ones will have no spark.
The way to check to make sure it's the coil and not the ignitor is to switch the leads/connectors of the leading and the trailing ignitor. The ignitors on located on the sides of the distributor.
When you switch the connectors on the ignitors and the car begins to make spark on the trailing plugs and not the leading plugs you know it's the ignitor.
If you get no spark at all, chances are it's the coil - but you can also check the coil using a voltmeter as well.
Check the FAQ for the 85 factory repair manual in the Engine Electrical section for pictures of all this stuff.
Old Mar 30, 2004 | 01:48 PM
white FD lover
your considered to be "the man" for now on hah, thanks bro, i was never aware that a tach was so much a part of the engine in that sense, where the damn sparks arn't firing, wow
Old Mar 31, 2004 | 03:23 PM
white FD lover
turns out to be the trailing ignitor after all, i switched ignitor and the tach started working so, thanks guys ..
Thor 18
Sep 28, 2015 07:35 PM
Casual_John
Canadian Forum
Sep 26, 2015 01:47 PM
subeone
Sep 24, 2015 09:58 PM
befarrer
Sep 22, 2015 09:33 AM
