How can I get rid of wheel hop?
Old Oct 28, 2001 | 10:14 PM
FEDREX's Avatar
"Just Looking".......
I get some good launches when I rev to 4500 or so, but if I stand on it the rear starts dancing and I don't want to break anything. I know I can ease off to remedy it but I'd rather be able to keep it floored and let the boost go.
Old Oct 28, 2001 | 10:56 PM
Freeway's Avatar
me too? though some kind of false logic I convinced myself that all imports hopped like that opposed to domestics that just spin... weird huh?
Old Oct 28, 2001 | 11:49 PM
Scott 89t2's Avatar
SOLD THE RX-7!
all cars get it, not just imports, my friend's chev used to be so bad.
get yourself some good rear shocks, and softer tires, 16" max, 15" would be better.
or course softer and smaller tires or worse for handling... so.
Old Oct 28, 2001 | 11:54 PM
mazdaspeed7's Avatar
mad scientist
Your rear spring rates are too high. Too stiff of a rear suspension causes the wheels ho hop instead of a nice, smooth spin. You also dont get as much weight transfer, and lose some of your launching ability. 150 LB springs would be much better on the back for launching.
Old Oct 29, 2001 | 12:20 AM
BLUE TII's Avatar
Rotary Motoring
srx7.com (shane racing) sells a rear bushing set that they claim eliminates wheel hop and is good for drag racing and road racing. It is expensive though... Make sure to check all engine, trans and diff mounts, bushings, shocks and even locking rear end; the problem is MUCH worse if everything is not perfect!
Old Oct 29, 2001 | 01:58 AM
dwillms's Avatar
No No NO!!!! The cure is simple. Soon as you feel the wheels starting to hop just put the clutch in a bit. I have the fastest starts now, and no more wheel hops.
-Daryl
Old Oct 29, 2001 | 11:00 AM
FEDREX's Avatar
Does this affect the cornering of the car at all. It's more important to me to keep the set-up I have as far as spring rates because it corners so well. If I were to reduce my rear spring rate in the back it would induce oversteer.
Old Oct 29, 2001 | 11:28 AM
RXTASY1's Avatar
I have heard that using old worn out springs in the rear is best.
That's what I use along with Nitto Drag Radials and have no hop.
Old Oct 29, 2001 | 03:25 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
Actually what they said about a softer spring is true. However, some things you can do:
If you have adjustable shocks, soften them up when drag racing.
Drop your rear tire pressure to about 20# for drag racing.
(Neither of those will help your cornering- they aren't good for autocross, or even "spirited" street driving...)
Also you might consider playing with your launch RPM... find the fine line between bogging and wheelhop.
Brad
Old Oct 29, 2001 | 03:58 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
Just get more rubber under the back if you cant spin them you cant hop them
actually they have given you the best advice. But also check your bushings and if your hearing a loud clunking sound it might be a differential mount.
Old Oct 29, 2001 | 05:49 PM
CanadianRX7's Avatar
yea just switch to normal suspension instead of sport.
thats what i do when i wanna light them up instead of jumping up and down
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
