General Question
Old Oct 28, 2001 | 08:14 PM
martini's Avatar
General Question
Theres something about my car that's been kinda irritating me for a while now.
When you guys are cruising along, foot off the gas, foot off the clutch, and then you get on the gas, even slightly, what does your car do? My car jolts everytime I get back on the gas, without slipping the clutch. It's annoying, and makes for a very unsmooth ride. Other cars that I drive do that, but not as violently.
Do all the rest of your FDs do this?
Old Oct 28, 2001 | 08:24 PM
the_saint's Avatar
No.
But the torque reaction strut brace might help prevent it. How are your engine mounts?
Mike.
Old Oct 29, 2001 | 03:09 AM
FD Racer's Avatar
sold the FD...kept the FB
Kinda sounds like a TPS problem.
Old Oct 29, 2001 | 06:33 AM
rpm_pwr's Avatar
yeah I had it but I dialled it out with an aftermarket ECU. Try the TPS that'd be my first guess. You have to expect some jolt though. These cars are built to respond to throttle quickly, no clutch slip, no momentary soft timing, just power surge.
-pete
Old Oct 29, 2001 | 03:41 PM
martini's Avatar
Well, it isn't a power surge...
it almost feels like the clutch isn't fully engaged, but then when I get on the throttle, it engages fully.
Sort of a jolt forward, and then it stops and goes back to normal acceleration. it's really hard to explain I guess. Oh well..maybe I'll just sell it.
Old Oct 29, 2001 | 04:24 PM
rpm_pwr's Avatar
hey martini, you're really crap at explaining things
The only other thing I could think of was the double throttle actuator. Make sure that works. If you've bypassed it, lock/wire it closed and test it then.
Your explanation does suck though. If your clutch wasn't fully engaged, when you got back on the throttle, the revs would just spin up then down. Plenty of cars I've had buck really bad with extremely light throttle openings. It's no coincidence that all of these cars were sports cars (more aggressive tuning) and had clutches with high clamping force.
Anyway, buy an rx-8 they've got twin electronic throttles. Problem solved.
-pete
Old Oct 29, 2001 | 04:33 PM
Hyperite's Avatar
Vagina Junction
Mine does that too....but i tuned it out with my foot. If I am in a lower gear at lower RPM, it's more noticeable, i can see the shifter bounce a little bit. But i've gotten used to it.
~Tom
_Tones_
May 25, 2021 05:37 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Nosferatu
Sep 5, 2015 02:13 PM
