MSD direct fire gains
Old Mar 27, 2004 | 07:24 PM
Static's Avatar
well mine will be installed soon and I was just wondering what I can expect in the HP and TQ gains as well as MPG gains or losses
Old Mar 27, 2004 | 07:32 PM
JIMMY54's Avatar
GSL-SE PRO
The car seemed to run smoother through all the rpm range, and started even better. Cant say about hp/Tq as i installed a lightweight flywheel right after.
Old Mar 27, 2004 | 08:21 PM
mwatson184's Avatar
holley guy
hp and tq not much, maybe some tq in the low low rpms that you never drive at (sub 2500). My car starts a lot easier and i get 1 or 2 mpg better, idles a little smoother as well.
Old Mar 27, 2004 | 10:19 PM
ioTus's Avatar
'84 5-letter
Most people have the "my car runs smoother now" response.
However, my understanding is, if hooked up correctly, incredible horsepower gains can be had by the addition of a capacitive discharge, multi spark system like an MSD.
You should also consider replacing teh aging coils. If you go w/ MSD, it is ADVISED you moutn them vertical. Mine are horizontal right now (stock), until i can finishthe mounting brackets.
~Geoff
Old Mar 27, 2004 | 11:32 PM
Northern 7's Avatar
I haven't seen or heard of any cases were there were "incredible" horsepower gains, - but I do know that the MSD is an excellent upgrade over stock ignitors, especially in direct fire mode replacing the leading ignitor. The MSD provides a stronger spark over a longer duration - both big plus's on a rotory. I've always said (IMO) it's the best money I ever spend on both of my 1st gens (carb and FI). Aside from the much improved idle and start up, I found the rev's between 5 and 7K to be much smoother and stronger and if you can improve in that range, you are most likely producing more HP.
Old Mar 28, 2004 | 12:49 AM
Jeff20B's Avatar
Lapping = Fapping
I still think it's a better idea to use a DIS coil when going MSD. I picked up a used FC leading coil recently for my MSD6AL.
Old Mar 28, 2004 | 09:14 AM
Static's Avatar
well the box came with 2 blaster 2 coils and 1 accel coil so I will prolly go with that setup first and try it out
Old Mar 28, 2004 | 10:49 AM
85rotarypower's Avatar
love the braaaap
I've read up to a 10hp gain in the higher rpm's. This would explain the smoother reving up to redline. I don't know about torque though.
Old Mar 28, 2004 | 11:55 AM
ioTus's Avatar
'84 5-letter
Maybe its just on turbo rotaries that the difference is so noticable.
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
windom
Sep 11, 2015 04:48 AM
