Was in car accident last night...
Old Mar 27, 2004 | 05:16 PM
phishie's Avatar
the rear wheel is cockeyed, havent got it up on a lift yet, but what do you guys is wrong with the suspension?
Old Mar 27, 2004 | 06:04 PM
phishie's Avatar
asd
asd
Old Mar 27, 2004 | 06:10 PM
IRPerformance's Avatar
Sponsor
prolly bent the toelink or control arm
phishie's Avatar
sdas
Old Mar 27, 2004 | 06:17 PM
phishie's Avatar
hard fix?
Old Mar 27, 2004 | 06:31 PM
mali_FC's Avatar
oops......speed bump....
try to take some pictures under the car.
compare each side( rear left and right wheel)
Old Mar 27, 2004 | 06:39 PM
jimlab's Avatar
Super Snuggles
Originally posted by phishie
hard fix?
Expensive fix.
Old Mar 27, 2004 | 08:11 PM
adam c's Avatar
Cheap Bastard
There is no way to know what is wrong without getting under the car, and looking at it. Any good alignment shop should be able to tell you what is bent/broken.
Old Mar 28, 2004 | 03:57 PM
phishie's Avatar
thanks guys all input is appreciated
Old Mar 28, 2004 | 04:06 PM
phishie's Avatar
Old Mar 30, 2004 | 12:13 AM
PVerdieck's Avatar
good luck
Old Mar 30, 2004 | 01:27 AM
rynberg's Avatar
Your body work will probably cost more than your suspension. Your quarter panel is fucked and will required a whole new panel to be welded in. That will cost at least $2.5k to DO IT RIGHT, if that's the only damage.
Old Mar 30, 2004 | 01:13 PM
Sponsor
I have some toe links and suspension pieces if you need them. PM me.
astrum
24
Nov 15, 2017 08:44 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
