just about sick..
Old Mar 27, 2004 | 05:01 PM
FB II's Avatar
just about sick..
ok, the people that have been helping now know that i have a holley on my 12a that's been giving me trouble. at first it would crank great with no problem, but had a stumble issue. i replaced the intake manifold gasket today and now it wont even ******* crank. i got brand new ngks, still doesnt crank. i reset the floats. STILL WONT GOD DAMN CRANK! so before i smashed the **** out of my windshield i just stopped ******* with it. i just dont ******* get it!!!!!! i changed nothing but the damn gasket. please help...
Old Mar 27, 2004 | 05:24 PM
FB II's Avatar
ok, now that i have calmed down, heres the rational thing. i pulled my plugs out to see if they were wet. the leading ones were just fine. look as if they hadnt been touched. the trailing though had a black residue on them. they were wet. what could cause this???
Old Mar 27, 2004 | 06:37 PM
mwatson184's Avatar
holley guy
You could just be flooded from all the cranking, pull the plugs out and pull the fuse for the fuel pump and crank the motor over to get all the fuel and crap out of there. Clean off the plugs and try to get her started. You are getting good compression right?
-Marques
Old Mar 28, 2004 | 12:27 AM
YapaKanichi's Avatar
Smile Like a Donut
fuel pump could be going sour....
Old Mar 28, 2004 | 12:58 AM
dont know if its any help but i know what black residue **** your talking about, i dont know what it is but it was on my plugs too. i said screw it and stuck em in anyway and it worked fine, and my car hasnt been cranked in 7 years...
Old Mar 28, 2004 | 02:02 AM
Jon_Valjean's Avatar
Ok dude, first thing you need to remember is self control. If you fly off the handle and smack something, you'll be repairing it at a later date, and you're going backwards. Just relax, if it ***** you off then back up a bit and go watch some simpsons or something. Jeez.
Now, go get a mate (friend for all you US people) and get them to tow start it. Get a long rope or a couple of old seatbelts and tow the thing for a mile or so - once it starts, let it run at 2000rpm for 10 minutes or so, then go nail it on a back road until it's cleared out. THEN you can decide how bad everything is, and if you need new gaskets or floats or whatever.
Old Mar 28, 2004 | 03:09 AM
mar3's Avatar
Administrator
  • Charge battery completely.
  • Get a vehicle next to yours and get the jumper cables connected between the two, then rev the other vehicle at a constant 2500rpm to engage high side of alternator output. Cables should be connected to battery in other vehicle; on your RX-7, positive to battery, negative cable clamp to alternator bracket, not the battery negative.
  • Spray Gumout Carb Cleaner down open primary throats and then spray air cleaner filter element and close lid.
  • Wait about 15 seconds for everything to vaporize nicely, step all the way down on the throttle, hold it there for 5 seconds and then start the car.
You shouldn't even have to pull the plugs for this and, no, car starting fluid will not do the same thing. This is based on experience.
Old Mar 28, 2004 | 08:58 AM
FB II's Avatar
mar3; i will go get some of that stuff and see what happens. thanks alot guys, and JON; thats exactly what i did. i walked away before i did something stupid. i usually dont flip out, but when everything is in tact and set but it still wont fire and nothing makes sense i just get way upset. this car hasnt run right in over 7 months.
deish
Dec 19, 2020 09:49 AM
dkwasherexd
West RX-7 Forum
138
Aug 28, 2008 03:52 AM
Black Hearts
RX-7 Audio/Visual Lounge
Aug 28, 2007 05:40 PM
gonzz
20B Forum
May 9, 2007 08:12 AM
