What do 89's & up have that I dont on my 88 for 15 more HP?!?!
Old Oct 28, 2001 | 06:25 PM
ItsNiceToBurnRice's Avatar
I wanna know, so that maybe I can do it, or get it. Either or, you guys know what I mean.
Old Oct 28, 2001 | 06:27 PM
mazdaspeed7's Avatar
mad scientist
Higher compression and the VDI intake manifold. The VDI manifold has been dynoed at 10 RWHP over the non VDI manifold on an 88 engine. And its not too hard to convert the 88 manifold to the VDI one. But I dont know exactly how to do it. Someone has a how-to online, but I dont know the link.
Old Oct 28, 2001 | 06:33 PM
Suparslinc's Avatar
It's Back!
ECU is six times faster too. I don't know if the engine design is any different I just know it has stronger components in '89+
Old Oct 28, 2001 | 06:38 PM
Alright
If I could convert, I would definetely try to tackle it-if anyone has the link, please hook a family member up
Old Oct 28, 2001 | 06:59 PM
vaughnc's Avatar
knowledge junkie
Also the 89-92s have 6.5 vs 5.5 PSI of boost.
If you want more HP, then just stepping up to a performance air intake, cold air box, perf. exhaust, and perf. catalytic converter will more than make up the 15PSI.
Just be sure to get an air/fuel & boost gague as you will be exceeding OEM boost levels.
Scott 89t2's Avatar
SOLD THE RX-7!
also lighter rotors and a 1000 rpm higher redline.
Old Oct 28, 2001 | 07:04 PM
mad scientist
He has a n/a.
Old Oct 28, 2001 | 09:09 PM
i am working on doing theconversion on my car.right now,i'm waiting till i get my 89 lower intake,i was hoping to use my 87 with the 89 upper,but 1 bolt does not line up.i will keep you posted as i go along,i'm taking off all my emission crap,wich makes it somewhat easier.the tb needs modification,i think it will work fine thou,i have to grind a "nub" off the bottom.and i am using a electronic vdi actuationand [and pulling out my aux.ports].if you have any more info let me know!!also,the oil metering pump actuation rod has to be changed,i will figuere it out when i grt around to it.later.
Old Oct 29, 2001 | 10:39 AM
hurleyboi514's Avatar
since its a 10 hp gain w/ vdi, would it be bad to bore mine out to larger specs? i was planning on doing that. bad idea? and what about takin out the 1st set of butterflies? i heard thats a help?
Old Oct 29, 2001 | 03:43 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
It's only 14hp not 15hp.
Reasons they have more HP:
More compression, LIGHTER rotors (lower rotating mass so it revs faster, and redlines 1000 RPM higher) different trailing ignition timing (the trailing spark plug locations are slightly different- this is more emissions related though) a faster ECU, VDI intake.
Reasons they aren't actually noticeably faster:
They are CONSIDERABLY heavier.
Brad
88 Convertible (yes, even heavier...)
3" single exhaust w/cat
wired open 6-ports
Bonez intake
Howe Racing radiator
Perma-cool electric fan (do NOT get one of these, they suck!)
FD alternator
Go to my website for "how to's" on the mods:
www.geocities.com/rx7_ragtop
16.15 @ 85 mph
