Oil Leak from oil filter mechanoid.
Old Mar 25, 2004 | 06:34 PM
von's Avatar
von
Buying a car that has a small oil leak coming not from the filter oil ring but the filter holder itself. Is this fixable from ouside the car or is this a special case of suckiness?
Thanks for the help guys/girls
Old Mar 25, 2004 | 06:52 PM
jdonnell's Avatar
Sounds like the pedastal (filter holder) o-rings. Theres two o-rings you cant see when looking at the oil filter on the pedastal. Reach under the pedastal and you should feel two nuts (I think 10mm). You'll have to drain the oil/remove filter, remove the 10mm nuts, and pull the pedastal. You'll see two o-rings, replace them. Takes about an hour.
Old Mar 25, 2004 | 07:42 PM
von's Avatar
von
awsome thanks.
Old Mar 25, 2004 | 08:19 PM
Digi7ech's Avatar
I break Diff mounts
Really easy fix.
They are 2 10mm nuts. a little hard to get at but simple.
Just go to the dealer ship and get the O rings. They are like 3 bux for both(when I got them).
It will also help save the Coolant hose under the pedastal. It gets soft and will rupture causing you to lose all your coolant and maybe engine if you don't catch it quick enough.
Snoopy FD
Dec 8, 2015 01:45 PM
Cameron38
Aug 19, 2015 06:08 PM
sypath
Aug 16, 2015 12:06 AM
