Any Tips on how to get strut mount nut off!
Old Mar 25, 2004 | 05:59 PM
13BTOY's Avatar
Boosted Fb
Whats the best way to get the 21mm nut off without removing the whole assy? I want to put my coil overs on but I'm lazy. I tried and the darn thing just keep on spinning.
Thanks, Ed
Old Mar 25, 2004 | 06:14 PM
JIMMY54's Avatar
GSL-SE PRO
Do you mean the bolt that holds the shock to that upper mount? The best way, is a powerful air gun....If not, you'll have to clamp the shock in some way and try your best to hold it while you loosen the top bolt
Old Mar 25, 2004 | 07:01 PM
13BTOY's Avatar
Boosted Fb
Yep! Thats the one. I guess theres no special socket for that 21mm nut? I tried to clamp it down with vise grips while I turned the nut on top but still no luck.
Thanks, Ed
Old Mar 25, 2004 | 08:10 PM
Siraniko's Avatar
RX for fun
its easier to loosen it while its in the car. the tension keeps the strut from turning. if you really dont care about the strut, a vice grip comes in handy.
Old Mar 25, 2004 | 08:28 PM
MicahMan's Avatar
That's Nice!!!!
i did that once. the best way is to use an impact with the 21 mm socket. use some penitrating oil and let it sit for a while before trying to take it off. i know that made it easier for me.
Old Mar 25, 2004 | 08:34 PM
13BTOY's Avatar
Boosted Fb
I think Im going to wait until my cars back on the road(waiting for a new pump) and drive to my buddies shop to have him zap it with an impact gun to loosen and drive it home for the swap(about 5 min. away). I just wanted to do as much as I could while the car was down.
Thanks, Ed
I'm HOPING the new pump will cure my high rpm miss/stumble.
old_skool
Sep 10, 2015 06:58 AM
