new coils and rims, fitment?
Old Mar 24, 2004 | 11:44 PM
nima_taba's Avatar
Hi,
I'm putting on some Tein coilovers and I'm wondering how much extra space I'll have between the inside wheel edge and the spring with these coilovers.
I'm planning to put on 18x8'' rims with a 40mm offset. That'll mean my inside wheel edge will move inwards 25mm (about 1inch)...do you think I'll get that much space out of the new coils?
Thanks,
Nima
Old Mar 25, 2004 | 12:22 AM
RETed's Avatar
The problem is that the stock shock system gets in the way at the bottom perch of the front strut.  Even with aftermarket coilover systems, you do not gain that much more clearance.
I, personally, don't think an 8" wide rim with +40mm offset will fit.
-Ted
Old Mar 25, 2004 | 12:36 AM
Russ's Avatar
-Ted
it'll fit he just wont be able to turn
Old Mar 25, 2004 | 01:21 AM
RRTEC's Avatar
Rotartist
why would you do that? You spend $1200 on coilovers to boost your handling and then blow it to hell with some big *** gangster sized wheels....If you are going for looks then just take the struts and springs out...It'll sit really low then... 18" wheels aren't going to turn worth a crap, i wouldn't go bigger then 17", I have 18"x on a vert i bought and the car turns / handles like ****. I got 16x7 on my se and they are pleanty big. 17's are almost to big for handling reasons.
Mps_hell
Sep 19, 2015 10:02 PM
MILOS7
Sep 16, 2015 06:34 AM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
