oil leak around oil filter neck area
Old Mar 24, 2004 | 08:20 PM
GEINN FC3S's Avatar
how do i make sure that this is whats causing the leak and not any other components near it, there is oil everywhere,so its very hard to tell. help!!
Old Mar 24, 2004 | 08:26 PM
hmm i fink i have the same problem as u
Old Mar 24, 2004 | 08:34 PM
GEINN FC3S's Avatar
around my place there is a junkyard that has a automatic s4 gxl, looked like it came straight from the dealer,low miles, had original paint and the motor was freakin clean as hell, no dirt or grime and that intake manifold was shining like hell, it was still silver bling bling lol, i couldnt beleive it, the good thing is not many rx7 owners go there, im like one of the few that go, and its all mine ! MUAHAHAHAHH lol, anything that breaks on my car i can get from there. yay! =)
Old Mar 24, 2004 | 09:22 PM
jon88se's Avatar
Eat, sleep, work, mod.
it's the o ring for the oil filter and it's pretty common...mine pissed out oil a few years back. I cut a new gasket myself and used a bunch of that gasket goop - problem solved.
Old Mar 24, 2004 | 09:46 PM
1SxyRXy's Avatar
my fc broke
yeah there are 2 o rings on the filler neck . there should be 2 10mm bolts holding it on. you take those off and off comes the part where you screw on the oil filter and just replace them. mine were a bitch to get off with the engine in. not sure if it might be hard for you with a NA but i image it will be very tediouse
Old Mar 24, 2004 | 09:53 PM
RETed's Avatar
Actually, it's a pair of 10mm nuts.
-Ted
Old Mar 24, 2004 | 10:43 PM
I got a stubby wrench set, but I can't get enough strength to take off the nuts, WTF, the tightening spec is 10ftlb, why can't I break em loose?
anyone knowany tricks?
Old Mar 25, 2004 | 08:34 AM
strikland's Avatar
My nuts came off pretty easy (hah hah)
like 1sxyRxy said, getting the wrench in there was a beotch. I was replacing the bypass cooling hose at the time, and having that out of the way helped. Still waiting for the o rings from mazdatrix to fix mine.
My advice: when all else fails, beat with a rubber mallet.
Old Mar 25, 2004 | 09:21 AM
jon88se's Avatar
spray some nuts off, let it sit - those nuts are probably 15 yrs old
Old May 1, 2004 | 10:20 PM
miketreid's Avatar
how much oil will this leak
How much oil does it leak when these o rings go?
Old May 2, 2004 | 12:31 AM
pyrojunkie's Avatar
It can leak a lot.
I just replaced my o-rings with some gasket goop. It had been leaking since I bought the car in Feb. I don't know how long it was leaking for, but mostly everything beneath the filter was covered in oil. The bottom plastic guard was pooling most of the oil, but you can easily notice oil spots on the ground after it sat for a day. I would say it leaked about 3/4 - 1 quart of oil a month along with daily driving during the time I had the problem.
Old Jul 5, 2004 | 02:16 PM
AusTexRex's Avatar
Anyone know the size of these o rings or are they a dealer part
Old Jul 5, 2004 | 04:26 PM
miketreid's Avatar
Got mine from advance auto parts
I took out the old one and got the match from Advance Auto Parts. They have o-rings of all sizes behind the desk.
Snoopy FD
Dec 8, 2015 01:45 PM
Cameron38
Aug 19, 2015 06:08 PM
sypath
Aug 16, 2015 12:06 AM
