Is the end near ..... ?
Old Mar 24, 2004 | 07:27 PM
yesterday i opened my hood after driving it and alot of smoke came out of the DRIVER side in the engine bay. It wasnt thick, or white.. kinda like exhaust fumes.
I recently just did a radator flush and had it filled up w/ antifreeze. Also my "add coolent" light keeps going on and off, even tho it jus had a flush and theres plenty of water in the reservior. ALSO my oil filter has a slight leak. It appears the steam is coolent, i checked the steam dew on the engine bay and it turned out green... or maybe it was there before ?! ...
well is there any connection between any of those ?
ANY help will be appreciated ! thanks... i hope this isnt the end of the rotary engine
Old Mar 24, 2004 | 07:29 PM
*a*jones*'s Avatar
definetly doesn't sound good....think it's time to hang'er up
Old Mar 24, 2004 | 07:32 PM
RXciting's Avatar
GrapefruitRacing?
well your coolant light coming on and off could just be the wire on your water level sensor on the top of the rad.. mine was stripped and corroded.. did the same thing.. replaced it and it stopped
Old Mar 24, 2004 | 08:28 PM
any possible problems ? waht could i do to fix it ?
cud b a coolent leak or its burning coolent or burning oil or something ... anyone got any other opinions?
Old Mar 24, 2004 | 08:29 PM
RXciting's Avatar
GrapefruitRacing?
can you find a place where coolant is coming from or where on the engine did you find coolant?
Old Mar 24, 2004 | 08:45 PM
poor_red_neck's Avatar
Wait................What?
Since the smoke is coming from the DRIVER'S side.. and the oil filter is on the DRIVERS SIDE and is leaking... um... did ya ever put 2 and 2 together?
-Jon
Old Mar 24, 2004 | 09:57 PM
B-ROB's Avatar
even though you flushed the coolant system...you could still have a few bubbles in it which settle near the coolant level sensor causing it to go off.
as for the smoke, probably the oil filter as previously stated.
Brad
Old Mar 24, 2004 | 09:58 PM
B-ROB's Avatar
Brad
Old Mar 24, 2004 | 10:02 PM
hmmm tats what i was thinking
but why would the oil filter cause so much smoke ?
Old Mar 24, 2004 | 11:43 PM
WTF
could possibly be the block->firewall coolant hose( the one for the heater core i think) maybe be split or has sprung a leak. thats what it was on mine
Old Mar 25, 2004 | 11:31 AM
*a*jones*'s Avatar
it would be leaking oil onto the hot engine making smoke.
Old Mar 25, 2004 | 11:41 AM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
The Coolant hose that goes rom the block to the firewall sits RIGHT UNDER the oil filter.. Oil and the rubber that the hose is made out of do not play well together. The hose will eventually fail after years of oil contamination.
How do i know this... 1) i've taken several chemical compatability course for my job.. 2) Last fall that damn hose sprung a leak on me right were it exits the block and initiated the overheating problems that did in my water seals and within a week made me take my car of the road before i blew it up!!! (started to smell antifreez in exhaust, impossible to start after parking the car after it was driven and warmed up)
EVERBODY... Check that HOSE for cracks, buldges and softness.. if you haven't changed it or it looks old.. change it and save yourself a big problem later.
I think its like 28 bucks from mazdatrix.
Old Mar 25, 2004 | 11:47 AM
Bauer778's Avatar
^ I had the same problem, that hose cracked and a whole bunch of steam came pouring out, it overheated because of it, i suggest that you change that hose as well
Old Mar 25, 2004 | 04:38 PM
Ok thats EXACTLY what happened, i went for a drive today parked it n opened the hood n the hose jus sprayed me w/ antifreeze !!
its leaking coolent everywhere !
anyone know what i should do to fix it ?
its smoking up alot and i had to run it at about 3/4 on hte temp gauge for 5 mins to get it home
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Wehavetocook
Sep 23, 2015 11:04 PM
Rotospectre
Sep 13, 2015 11:22 PM
