where are the secondary fuel injector wires?
Old Mar 24, 2004 | 12:21 PM
cwsttu's Avatar
1.3L is not that small
i would like to look and see if maybe i bumped them off because my car hits a brick wall when i give it some gas and from searching a thread said maybe the secondary injector harness got loose.. all i can find are the primaries and the chiltons manual i have is **** so i cannot find the secondary fuel injectors and the plugs that go to them.. thanks in advance
christopher
Old Mar 24, 2004 | 12:30 PM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
Dude.. I think you have found the secondaries.... if you haven't torn the UIM and mid plate off if you have an N/A... The primaries are down under everything else and they sit right into the intermediate housing of the engine itself. Their wiring harness runs under the intake manifold(s) from the drivers side of the engine, right across the top of the engine.
Old Mar 24, 2004 | 12:32 PM
cwsttu's Avatar
oh ok i thought the ones right under the intake tubing next to the throttle body was the primaries.... thanks for the info
Old Apr 16, 2004 | 10:50 PM
version13's Avatar
Exhaust leak
So where are the primaries?
Old Apr 17, 2004 | 02:44 AM
NZConvertible's Avatar
I'm a boost creep...
Re: where are the secondary fuel injector wires?
Originally posted by cwsttu
...my car hits a brick wall when i give it some gas...
Can you elaborate? What rpm does this happen at? Can you accelerate any further?
Er, didn't you read YearsOfDecay's post?
Snoopy FD
Dec 8, 2015 01:45 PM
82streetracer
Aug 23, 2015 09:28 AM
