Shifter vibrates when car is "ON" but not started...
Old Mar 24, 2004 | 01:23 AM
poor_red_neck's Avatar
Wait................What?
heh... searched, just for the hell of it, thought I'd post it.
I thought it was my fuel pump.... but it can't be THAT loud. I don't hear it, but I can feel it on the shifter. Its a very faint vibration, but I know its there. When the key is "ON" it does it, when I start the car I OBVIOUSLY couldn't tell, and when the key is off... it goes away.
Car is in "N" and all fans/stereos or whatever are off.
Could it be the OMP?
I thought it would be... but my block is a S4; all S5 intake and exaust and ****... just the block, and rotors are S4. I'm not sure, but I'm pretty sure the S4's mechanical OMP is on there. Unless the S5 electric OMP can go on the S4 block... its S4. Any other guesses?
Old Mar 24, 2004 | 05:09 AM
BOOSTED Vert
Its the fuel pump.
Old Mar 24, 2004 | 09:06 AM
Kenseto's Avatar
have you tried exorcism?
Old Mar 24, 2004 | 09:28 AM
RoninAutoBoX's Avatar
Old School Rotors
Have you upgraded to the new oiuja style shifter?
Old Mar 24, 2004 | 09:40 AM
YearsOfDecay's Avatar
Locust of the apocalypse
From: Directly above the center of the earth (York, PA)
Or from the Latin fuelis pumpis maximus volumis
you wanna check it... just get under the hood and pull the egi fuse... then try again.. betch don't feel it!!!
Old Mar 24, 2004 | 12:34 PM
kool.
thx guys.
Old Mar 24, 2004 | 02:18 PM
neevosh's Avatar
The Dude Abides
The fuel pump isn't on when the key is in the "ON" position.
Old Mar 24, 2004 | 02:42 PM
Wanked_FC's Avatar
Ihre Papieren, Bitte?
hmmm, then when the car is running how does it get fuel, seeing as its "on" when its on.
Old Mar 24, 2004 | 03:40 PM
BOOSTED Vert
Are you sure you want to stick to that statemen??
Old Mar 26, 2004 | 06:45 PM
neevosh's Avatar
The Dude Abides
The fuel pump is only on when the car is running. Just having the key to the ON position won't turn it on.
Old Mar 26, 2004 | 07:35 PM
CRXtoRX7's Avatar
mmmtrbo.
I got 5 bucks says yur wrong, bud.
(yes that was in hick accent....)
Old Mar 26, 2004 | 07:41 PM
Project84's Avatar
Open up! Search Warrant!
The pump should come on to prime the system when the key is in the on position.
Old Mar 26, 2004 | 10:47 PM
BOOSTED Vert
um, no.
Old Mar 27, 2004 | 01:44 AM
neevosh's Avatar
The Dude Abides
Mine doesn't turn on until the car is on.
Old Mar 27, 2004 | 02:55 AM
BOOSTED Vert
how do you know ??
Old Mar 27, 2004 | 03:13 AM
gildardo's Avatar
FC Revolution
I had the starts and dies in 2 seconds, and i learned a lot from that. THe fuel pump only runs when the engine is running or when cranking the engine.
Only way the fuel pump could be running is if the yellow jumper in the engine bay is jumped or the AFM is a bit open. that is with the engine not running and key with ignition on.
My problem was that one of the wires leading from the circuit opening relay wasn't making contact somewhere under the dash, so I just ran a new wire to the engine wire harness.
Old Mar 27, 2004 | 04:18 PM
Incorrect on the only running while on/starting. The fuel pump will have a ~~ 2 second prime mode when you FIRST turn the car on, then it turns off (not a pressure switched prime, just time only). Then when the car is running or cranking, the fuel pump is back on.
Old Mar 27, 2004 | 10:44 PM
neevosh's Avatar
The Dude Abides
It might turn on and prime, but my point is that it's not on constantly in the "ON" position. The original poster asked what could cause his shifter to vibrate with the key in the "ON" position. I said it couldn't be the fuel pump because it's not running constantly without the car running. That was the point I was trying to make.
Also, my car doesn't prime the fuel system with the key in the ON position. I don't hear the pump running and I certainly don't see any change in fuel pressure on my guage.
Old Mar 27, 2004 | 10:45 PM
neevosh's Avatar
The Dude Abides
Old Mar 28, 2004 | 02:22 AM
CRXtoRX7's Avatar
mmmtrbo.
Do you have the stock pump or aftermarket? I have the RP pump, and it is definately audible with the car in the on position. If you want to prove yourself wrong, go out and check the pump wires for the 12v in the on position.
Old Mar 28, 2004 | 04:54 PM
neevosh's Avatar
The Dude Abides
There, I proved myself right. My car's fuel pump doesn't see any voltage until I crank the engine or bridge the terminals of the yellow plug.
Old Mar 28, 2004 | 07:58 PM
turbo II addict's Avatar
he is right when i replaced my fuel pumpo i wnated to make sure it worked right so i turned the key to on and nothing happend make a long story short 2 hours later i found out it needs a crank signal before it turns on so it dosnt flood god knows rx7 have enough of a problem with flooding allready they dont need more
Old Mar 29, 2004 | 12:09 AM
BOOSTED Vert
just because the FP runs doesnt mean the car will flood. Injectors wont open w/o ecu signal.
Old Mar 29, 2004 | 02:45 AM
NZConvertible's Avatar
I'm a boost creep...
Okay, the fuel pump does not run at all if you just turn the key to ON. No priming, nothing. It will not run unless the key is in the START position or the AFM registers airflow. So it's not the pump.
I dunno if you'd feel it in the cabin, but the BAC valve is being operated by the ECU when you turn the key to ON. It's being rapidly oscillated open and closed, so it makes a buzzing sound that you might feel through the shifter.
Old Mar 29, 2004 | 03:13 AM
CRXtoRX7's Avatar
mmmtrbo.
havent drivin my car in a while, but I thought when it was in the on position you could hear that badboy pumpin away...my bad
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
NoMorePoison
11
Aug 18, 2015 11:18 AM
