Leaky rad cap= idle problems?
Old Mar 24, 2004 | 12:48 AM
The Spyder's Avatar
Never give up!
My upper rad cap started leaking.... BAD.....
Now my car wont idle and dies under 2k if I remove my foot.
I noticed the leak and saw a bunch of wires SOAKED with coolant.
I assume these are the auto idle controls??? Will drying it out/replacing the cap solve this?
The only thing else I did was clean the intake, dont see anything wrong?
Old Mar 24, 2004 | 01:02 AM
den's Avatar
den
change the rad cap, dry the wires/connectors and see what happens. if you've just cleaned the intake and now have a dodgy idle i'd bet you've knocked off a vac line or damaged something around the intake.
Old Mar 24, 2004 | 01:14 AM
The Spyder's Avatar
Never give up!
*By clean* I mean take a wire brush to it.
I will give it a good look over tommorow.
Old Mar 24, 2004 | 02:40 AM
skunks's Avatar
I'm a CF and poop smith
leaky rad cap=over heating=dead engine hahaha
Old Mar 24, 2004 | 04:01 AM
The Spyder's Avatar
Never give up!
Yeah Im also checking the thermostat tommorow to make sure it works.
Want this motor to last me a while...
Old Mar 24, 2004 | 04:04 AM
BOOSTED Vert
Does this happen while its hot and cold or just when its cold start up?
Old Mar 24, 2004 | 04:12 AM
The Spyder's Avatar
Never give up!
the leaky cap, or the idle??
The idle was fine until it started to leak.
It was a bit off. 1.5k drop to 1k, repeat until settled. Then it was fine at like 950rpm....
Old Mar 24, 2004 | 05:27 AM
SiGmA_X's Avatar
Steady at 750rpm, after it was warmed up.
Old Mar 24, 2004 | 03:47 PM
BOOSTED Vert
If it runs fine after warmup then its probably your thermostat. Its probably stuck open. Although after a few quick revs it should come down to near normal idle.
Old Mar 24, 2004 | 04:02 PM
Kenteth's Avatar
Like Ghandi with a gun
Are you the guy from GenMay by chance? Happy 19th
rotor_veux
46
Jun 12, 2018 10:39 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
