spring arm/fast-idle cam pivot screw seized
Old Mar 23, 2004 | 08:10 AM
pip's Avatar
pip
the blackest incarnation
Ive tried everything to get this screw out without damaging it but the more things I try the worse it gets. Its not stripped but its getting there pretty quick any suggestions?
Old Mar 23, 2004 | 11:27 AM
pip's Avatar
pip
^bump^
Old Mar 23, 2004 | 01:35 PM
SureShot's Avatar
Seduced by the DARK SIDE
Which screw is it?
I'd go for the vise grip pliers.
Old Mar 23, 2004 | 01:51 PM
Digi7ech's Avatar
I break Diff mounts
Well. Get a dremel or something and cut your own deep slot to help undo it.
You can't really use vice grips because it is a small screw on the end of a pillar.
pip's Avatar
pip
this one
Old Mar 23, 2004 | 02:13 PM
Nick86's Avatar
Yup, still here
Go to Sears and get a Screw-Out extractor set. They work well for stuff like this. You drill out the stripped middle of the screw, and then the extractor pulls it out:
You can get cheaper versions at other stores like this:
If buying tools is not possible - then soak it in relasing fluid, and add heat.
Worst case is that uou have to drill it out and retap the hole.
Old Mar 23, 2004 | 02:55 PM
pip's Avatar
pip
Thanks, i think ill try the screw out thing first since I can think of more than one shitty screw on my car that I didnt feel like retapping.
Old Mar 23, 2004 | 02:58 PM
RETed's Avatar
Use lots of penetrant.
I like to use a smal vice grips to grip the head and twist to loosen.
Sometimes it helps to file down two opposite sides so the vice grip has a better time gripping the screw head.
A torch can help with very stubborn screws too.
-Ted
Old Mar 23, 2004 | 03:10 PM
pip's Avatar
pip
Yeah I used a TON of liquid wrench on it , im gonna try filing the sides down and letting the vice grips have a go at her.
Old Mar 23, 2004 | 03:13 PM
SureShot's Avatar
Ted's been there.
I've been known to dress the tips of my vise grips to get a bite on a screw head.
The last one was on the fuel pump pickup strainer.
Old Mar 23, 2004 | 10:13 PM
dont file down the sides to use vice grips I just clamp them on so hard it bends the screw head to a flat surface
Old Mar 24, 2004 | 10:36 AM
HAILERS's Avatar
HAILERS
Originally posted by pip
this one
EDIT: Error on my part. That is a good picture of the thermowax, fast idle cam etc for folk who don't know what it is.
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
vxturboxv
Sep 16, 2015 04:16 PM
Ernstudet22
Sep 14, 2015 09:19 PM
