K2RD Susp problems!
Old Mar 22, 2004 | 05:29 PM
87GXLRX7's Avatar
K2RD Susp problems!
i installed the K2Rd Susp coilover set up, GC Coilovers, Pillowball mounts, and AGX 8 way adjustables. i get a loud clunking sound if i hit any small bump. it chatters almost, and i have the car set at the stock level.. any ideas? thanks
Old Mar 22, 2004 | 05:36 PM
enrique's Avatar
pillow ***** tighten to the strut tower?
Old Mar 22, 2004 | 07:33 PM
Gene's Avatar
10 lb. boost, 5lb. bag
Set at stock level with that stiff setup? (I have the same one)
Yeah, check that everything is tight. Check that your diff mount isn't broken too... though the diff mount usually makes itself known when accelerating, not on bumps...
Old Mar 22, 2004 | 08:24 PM
Scott 89t2's Avatar
SOLD THE RX-7!
some noise is kinda normal with sleeved coil overs...
comon thing to do is wrap duct tape around the shock where the sleeve sits to make the sleeve tight against the shock.
Old Mar 22, 2004 | 08:42 PM
7'sfalife's Avatar
I have the exact setup, I did the duct tape wrap and it works! Mine was makeing the same sound you described. Your best bet is to go with the duct tape!
Old Mar 22, 2004 | 10:25 PM
87GXLRX7's Avatar
well i have duct tape around them.. but maybe its not enough they aren't lose.. but maybe u could make them tighter.. my only idea is maybe one of the 2 washers is in the wrong place..???
Old Mar 23, 2004 | 01:56 PM
vaughnc's Avatar
knowledge junkie
Someone post pics of this, I can't picture where the sleeve would go.
I've got GC coilovers on non-adj tokicos, but the only noise they make is when I bottom out or the hatch pops when I hit a hard bump.
BTW - I think coilovers can be soft as a regular spring/strut setup, but mine must be for racing only.
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
