CP Rack&Pinion steering conversion
Old Mar 21, 2004 | 10:02 AM
Has anyone got this in yet? What do you think of it ?I sounds great, the stock steering is pretty shitty,IMHO. It looks great and apparently a simple bolt-on.
In general their products sound great especially the Fender Flares and Flush mount light kit. Everytime I see one of these sites I want to buy everything!
Old Mar 21, 2004 | 10:20 AM
ASEmaster's Avatar
I just posted about my install. I will tell you now, the installation (at least in my case) was a bit more difficult than a simple "bolt on".
Old Mar 21, 2004 | 10:38 AM
Anex 570's Avatar
It Runs!
Did you yank the motor out, or have it lifted and do it from underneath?
Old Mar 21, 2004 | 11:31 AM
ASEmaster's Avatar
You shouldn't have to do anything with the motor according to the instructions. It definitely doesn't need to be removed. I did have to pull it off the mounts slightly with a hoist so that I could put a couple of 1/4" spacers under the mounts because my oil pan was touching the new rack, but it's not supposed to have the clearance issue I ran into. I detailed everything in my earlier post, check it out.
Old Mar 21, 2004 | 07:55 PM
Paulo-Rx7's Avatar
If you unbolt the u-clamp and tap off the bracket that is touching the pan and bring it to the grinder then round the edge problem solved. No need for spacers..... also
do you have old motor mounts, they tend to sag.
Paulo
Old Mar 21, 2004 | 08:22 PM
ASEmaster's Avatar
I put new mounts in it after noticing the interference, it had no effect new mounts vs. old mounts.
Old Mar 21, 2004 | 09:29 PM
Paulo-Rx7's Avatar
You didnt read my post correctly the part about the bracket and u-clamp then you round the square edge on the bench grinder. you guys act like a bunch of babies when it comes to aftermarket parts. when has anything fit with out adjustments? IMHO paulo
Old Mar 23, 2004 | 01:27 AM
rotarygod's Avatar
Rotors still spinning
No need to be so harsh. He likes it! BTW: Properly designed parts don't need to be modified or ground down with a bench grinder to fit correctly. When you pay $600 for a part it should fit perfectly. It should also have at least an equal amount of steering travel as the stock unit. I'm probably being a baby about it though! That's what happens when you set your expectations high I guess.
Regardless I still feel this is a good product. Luckily I can modify things easily.
Old Mar 23, 2004 | 01:44 AM
I'm looking into getting this steering conversion too... up where i live is too nuts to be reaming on the stearing wheel forever before it actually turns enough to go around these corners.
Old Mar 23, 2004 | 04:54 AM
ASEmaster's Avatar
Not to mention the fact that if you were to modify the aftermarket product, you would most likely void any kind of warranty that came with it.
Old Jun 11, 2004 | 11:09 AM
joemkr's Avatar
has anybody ever adapted a 2nd gen rack to a 1st. gen app?
Old Jun 11, 2004 | 09:33 PM
Frankenrex's Avatar
On the CP Racing R&P, I'm curious about the attachment to the column. I understand that you have to cut the lower tune and seperate the shaft at the collapse joint. What if you have a GSL-SE? Those already have a u-joint at the firewall.
Old Jun 12, 2004 | 06:31 AM
RX7145's Avatar
-SE with Mods
You must have a manual steering column.
Old Jun 12, 2004 | 01:04 PM
bouis's Avatar
Doing it like CP says ruins the steering box. I'd think that it's real easy to get an upper column shaft and tube out of a junked car. Since you wouldn't be taking the box you'd probably get it for cheap (assuming they didn't realize that you're ruining it). If I had it to do again that's how I'd do it.
Old Jun 12, 2004 | 03:59 PM
82transam's Avatar
Never Follow
It ruins the box? I thought it ruins the lower half of the column but left the box in tact, or is that one in the same...
Old Jun 12, 2004 | 04:40 PM
Frankenrex's Avatar
The shaft is part of the steering box on FBs. Part of what makes them such a pain to swap - big long shaft running all the way from the steering box to the steering wheel, all one piece (except for the collapsable section.)
Old Jun 13, 2004 | 05:09 PM
82transam's Avatar
Never Follow
damn that sucks, I didn't realize it was all one thing, when I took it out of my project I removed it all as one piece so I didn't even look that close to confirm it.
Old Jun 14, 2004 | 10:35 AM
Frankenrex's Avatar
Yeah, dunno why Mazda didn't just put a rag joun at the box like everyone else. Yes, it's a little sleeker their way. I must admit it is pretty slick having the shaft totally enclosed like that - no worries about wires wrapping around the shaft or whatever. Soe sort of coupler just inside the tube at the steering box end would have been nice, though.
Old Jun 14, 2004 | 02:31 PM
abeomid's Avatar
Here u go:
https://www.rx7club.com/showthread.p...light=subframe
RyanFox
Sep 18, 2015 09:09 PM
