87-88 and 89-91 T2 transmissions, whats the diff?
Old Oct 27, 2001 | 09:22 AM
setzep's Avatar
I need to buy a T2 trans for my T2 transplant into my 83 and was wondering which one was better? Is one stronger than the other? I know that the 5th gear is a little diff from the two but what else?
Old Oct 27, 2001 | 10:30 AM
t_mak@mail.plymouth.edu's Avatar
89+ hjave better gear ratios, more aggressive. Also their throws are shorter and the transmission is stronger internally
Old Oct 27, 2001 | 12:16 PM
setzep's Avatar
87 T2 ratios:
1st 3.483
2nd 2.015
3rd 1.391
4th 1.000
5th .762
89 T2 ratios:
only change from 87 is 5th is .756
91 T2 ratios:
only change from previous T2 trans is 5th .719
So there goes that "more agressive ratios" out the window. Based on the ratios I'd want to get the 87 one for the less granny 5th gear. But I guess the major concern to me is will a n/a rear extention housing from a FB fit on a 89+ trans? I know it will fit the 87-88 ones because I know of someone that has done it.
Old Oct 27, 2001 | 03:55 PM
rx7passion's Avatar
why dont you buy my trans came right out of a t2 truck j/k
Old Oct 27, 2001 | 08:00 PM
Scott 89t2's Avatar
SOLD THE RX-7!
the diff is in the back and has nothing to do with the tranny
haha, we need a smilie that says "smart *ss"
Old Oct 27, 2001 | 08:27 PM
I dont have my shop manual here, but the T2 have a higher ratios in every gear
NA remained unchanged except for 5th gear
Old Oct 28, 2001 | 12:48 AM
setzep's Avatar
hmm... my Mazda book must be wrong.
Old Oct 28, 2001 | 09:15 AM
takerwolf's Avatar
Will a 89-91 turbo tranny or 3rd gen tranny work in a 87 turbo with no modification?
Old Oct 28, 2001 | 09:23 AM
13BAce's Avatar
On a long vacation
89-91 will work if you have the 89-91 mount. A 3rd gen won't bolt right in.
Old Oct 28, 2001 | 10:27 AM
takerwolf's Avatar
How hard is it to put an 89 mount on and does the tranny bolt right to the engine and use the same driveshaft?
Old Oct 28, 2001 | 10:41 AM
13BAce's Avatar
On a long vacation
The mount goes on the transmission. Yes, it will bolt to the engine and use the same driveshaft.
1NSIGHT
Drifting
Sep 29, 2015 12:18 PM
