clunky shifting
Old Mar 19, 2004 | 11:28 PM
voodoosporko's Avatar
clunky shifting
Hey, Im driving an 85 GSL. The car shifts smoothly sometimes..but alot of times it is very clunky feeling. Recently, when I engage or disengage the clutch, i can here a small thunk. I also changed out the tranny oil the other day with some redline, when I pulled the bottom plug off, it had a bunch of stuff that looked like metal scrappings on the top...Am I looking at rebuilding the tranny? new clutch? both?
Thanks in advance
Old Mar 19, 2004 | 11:40 PM
84stock's Avatar
Metal stuff is a very bad sign, syncros could be worn and that's offering inconsistant shifting if some of the teeth are broken. Rebuilding could get costly, look for a good used one instead. I have 160,000 km, use synthetic oil and shift like butter. I remember going through the rebuild thing with a munci behind a 396 in a chevelle, ended up just replacing the whole damn thing in the long run.
Old Mar 19, 2004 | 11:44 PM
YapaKanichi's Avatar
Smile Like a Donut
I read somewhere that rx7s didn't have synchros in their trannies....but I'm not sure of that's true now.
Old Mar 20, 2004 | 12:24 AM
Keaponlaffen's Avatar
definately have synchros, otherwise you'd grind gears everytime you changed gears, unless you double-clutched.
Old Mar 20, 2004 | 12:56 PM
mazdaverx713b's Avatar
Have RX-7, will restore
th eclunking could be a bad input shaft or its bearings.
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
Rotafuzz
Sep 30, 2015 09:55 AM
