Help!! hot oil shooting out car
Old Mar 19, 2004 | 03:49 PM
Yeahh, right when I am about to finish my car, something has to go wrong. I was driving around on this nice day when my car started running like it was only running on one rotor and there was a faint amount of smoke but bareley. I pull over on the spot and open the hood. I find out that the hot *** oil is coming out of a little nosel that is attached to the part where you pour in the oil. But I couldn't see any coming out when it was at idle.
Why is there hot *** oil coming out of that nosel?
I cleaned all of the contacts and the car is still running bad, please tell me its like some kind of oil mgt. sys that just isn't working? If you need any more info id be glad to tell you oh yeah the oil pressure is still staying at around 60psi
Heres whats in it:
-20,000 miles on new 13b
-racing beat s/s header to customized 2 1/2"
going to dynomax 2 1/2" muffler
-Racing beat clutch
-Wings west bodykit
-15" x 7" Eagle polished aluminum rims w/ Potenzas
-Eibach Springs
-Tokiko Illumina 5 way adj shocks and struts
-Mazdatrix 4.444 rear end
-Webber 44 carb made for racing w/ a fabricated stop
sign for the air cleaner holder
-Holly blue electric fuel pump/regulator
-Modified "hurst" short shifter
-6 ports always open
Old Mar 19, 2004 | 04:16 PM
mwatson184's Avatar
holley guy
You might have way to much oil in there.
mwatson184's Avatar
holley guy
oh is the 60 psi of oil pressure at idle? Or just while driving. Should be closer to 30 or 35 at idle.
Old Mar 19, 2004 | 04:18 PM
yeah The dipstic is reading to much oil, but it ran fine the other 5 days in the last 2 months I drove it, I am going to let some oil out and see... gracious, could that be why my engine is struggling?
Old Mar 19, 2004 | 04:21 PM
mazdaverx713b's Avatar
Have RX-7, will restore
too much oil equals too much oil pressure and it is kicking it up the only way it can go. the small protusion is a crankcase vent. do not add too much oil next time!!!!
Old Mar 19, 2004 | 04:40 PM
I got the oil down but it is still doing the same thing with the engine running (1 rotor) I am taking the plugs out and cleaning them right when I get done typing this hopefully that works... any other ideas?
Old Mar 19, 2004 | 05:26 PM
ok did a compression test and it said 100 on the front and 80 on the back, blown engine? if so im shipping this baby to texas and putting in some lightweight rotors
HELP
Old Mar 19, 2004 | 05:45 PM
ahhhh. nothing, im going to look up this crankcase venting thing honestly I have no Idea what that means but ill do my best
Old Mar 19, 2004 | 05:51 PM
if it is still squirting oil out of the tube after you drained some out, you are getting pressure from somewhere in yor system. where, i don't know. why i wouldn't begin to guess. i have never heard of this. sometimes i get a bit of steam coming from my tube. thats it.
Old Mar 19, 2004 | 05:57 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
80psi rear is low.
drain the oil, see ifi there's metal in there. be sure to pour a quart of oil or ATF into the motor after you drain it; that way it'll get sludge and metal particles out of the bottom of the pan.
check your oil filter for metal.
did the dip stick pop out? if so the side seals are bad and compression leaking out of them and into the crankcase.
Old Mar 19, 2004 | 06:01 PM
Ill be checking on that right when I get back from a wake, got to clean up right now. But its weird, I kind of got mad and reved the engine w/ the oil cap off,, **** loads of white smoke came up and landed as dirty oil all over my car, why is oil smoke shooting out of there?
Old Mar 19, 2004 | 06:49 PM
DriveFast7's Avatar
i sense a rebuild in the immediate future.
Old Mar 19, 2004 | 07:43 PM
Unsupa's Avatar
Blew my 3rd one 12/8/08
real immediate.. my friend's motor lost the rear rotor and had white smoke coming out his oil cap trying to start it.
Old Mar 19, 2004 | 08:57 PM
Fuel524's Avatar
drivefast7 just ppur ATF after you drain oil then put drain plug back on then ATF let it sit for a min???? i am in terested in this method for i am going to change my drain pan gaskeet tomorrow should i do this or just clean out pan by hand?
Old Mar 20, 2004 | 05:03 AM
Well I think that the oil thingie "got drunk tonight to forget so" any who that oil seal in the rear rotor is messed. I am just going to sell my 44 idf webber and intake manafold. Along with my racing beat stainless steel headers to straightpipe to 2.5 dynomax muffler. I found a guy with a turbo 2 engine and rotor, all I will have to do is get a computer and change the primary injectors with my first gens and I should be grand.. hopefully
dkwasherexd
May 27, 2017 04:51 AM
gtcd
30
Aug 19, 2015 02:44 AM
