Oil Cooler ??????
Old Mar 19, 2004 | 01:54 AM
justrx8's Avatar
Oil Cooler ??????
WILL A OIL COOLER FROM A 85 GSL-SE FIT AN 84 GSL
PEDRO
Old Mar 19, 2004 | 02:12 AM
Jeff20B's Avatar
Lapping = Fapping
Sure.
Old Mar 19, 2004 | 08:42 PM
mazdaverx713b's Avatar
Have RX-7, will restore
it will fit a 12A or a 13B.
Old Mar 19, 2004 | 09:47 PM
hornbm's Avatar
FD > FB > FC
yep sure will, you just gotta make your own lines. If you do their chaper than the stock ones anyway, and they look way better. Just get some -10 braided stainless steel hose and some -10AN fittings and your good to go.
Old Mar 19, 2004 | 11:55 PM
TexasGunRunner's Avatar
oil cooler generations
Can somebody give a quick summary of the oil cooler generations and differences?
I vaguely recall the early models (SA) were the same as the SE design, but I can't find that now. Were they interchangeable?
...and the '86+ gen 2 coolers look similar, but another thread I found said there was something that required modifications to put in an GSL-SE. Are they interchangeable, or how can they be changed to fit?
My 84 GSL-SE fell off the jack stands without the wheels on (I am still kicking myself - totally my fault), and one of the jack stands which slid on its side sliced through the valance, rock shield, dented the cross-frame/support tube and nicked/crushed part the oil cooler. It might be OK, but I want to know just in case I have to replace it.
Thanks,
Brian T. Carter
Old Mar 20, 2004 | 11:05 PM
riceburner1r2001's Avatar
I KNOW THE BIGGEST OIL I KNOW OF IS THE 1S FROM THE REPU. 7ROW
Old Mar 21, 2004 | 11:04 AM
Rex4Life's Avatar
RX-7 Alumni
As far as front mount oil coolers go the RX-7's go there are three versions:
1) early FB's (and SA's I think)
2) the 84/85 gsl-se
3) series 4/5 oil coolers
They are all different in mounting and connections, but I think they all have the same cooling and thermostat settings. I believe all FB coolers use the same fittings for connection but the nozzles are located at different angles between 1 and 2 above. The FC coolers use banjo bolts which are better but will require custom work to install on a FB.
I'm pretty sure all 84/85 chassis have the mounts for the gsl-se oil cooler. So if you have an 84/85 that is obviously the best way to go.
Search around more info is out there on this subject.
Good luck,
Scott
Old Mar 21, 2004 | 09:34 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
the REPU and Rx4 had an 8 row oil cooler and more square inchage than any 1st gen.
Old Mar 21, 2004 | 09:56 PM
Fuel524's Avatar
so an Rx4 or REPU is better at cooling oil? or just holds more oil?
Old Mar 22, 2004 | 01:15 AM
justrx8's Avatar
ok well guys where can i get one that will fit an 84 gsl with a 12a
pedro
Old Mar 22, 2004 | 11:22 AM
DriveFast7's Avatar
Yes.
Old Mar 22, 2004 | 01:05 PM
Jeff20B's Avatar
Lapping = Fapping
The REPU/Cosmo and I suppose RX-4 have a couple more rows of fins and one or maybe two more oil tube passages than your typical SA/FB type. So in other words, sure!
Old Mar 22, 2004 | 02:14 PM
Fuel524's Avatar
thats what im buyin lower oil temps and coolant temps loger life and more reliable ponies. isnt it said you should try and keep your oil temps the same as your coolant temps or other way around?
Old Mar 24, 2004 | 10:22 PM
Siraniko's Avatar
RX for fun
Top = RX-7
Bottom = RX-4
Old Mar 24, 2004 | 10:30 PM
Fuel524's Avatar
theyre the same fukin thing
Old Mar 24, 2004 | 10:38 PM
kettlman's Avatar
THE ONE. THE ONLY!
actually the rx-4's is a little bigger. not much, but it is bigger.
Old Mar 24, 2004 | 11:23 PM
Siraniko's Avatar
RX for fun
wrong...the bottom has an extra row. so there's total of 8 rows, instead of 7 like the 1st gens'
Old Mar 25, 2004 | 12:35 AM
Unsupa's Avatar
Blew my 3rd one 12/8/08
i got an oil cooler off an gslse. If anyone's interested in buying it, PM me.. i'll throw in the pedestal for the oil filter as well.
Old Mar 25, 2004 | 02:28 AM
Jeff20B's Avatar
Lapping = Fapping
Ah, so it has 8 rows after all. I sort of decided to go with air oil cooler. It's like the one at the top of the pic. I started test fitting it tonight.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
