Microtech Sending LT-8 through a dry run
Old Mar 18, 2004 | 11:03 PM
HIMNI Racing's Avatar
Rick James
Question Sending LT-8 through a dry run
I remember reading some place that there is a way to make the LT pulse the injectors without running the engine, to make sure that each one is firing right.
How do I do this?
Old Mar 18, 2004 | 11:16 PM
LT8TurboII's Avatar
Under the config setting where you set the number of cylinders set it to 0, this will put you in test mode.
Old Mar 19, 2004 | 01:24 AM
RETed's Avatar
Ignition ON
Pull CAS and spin manually
-Ted
Old Mar 19, 2004 | 08:56 AM
A-Spec Tuning's Avatar
Registered User
yes exactly...as "LT8TurboII" stated this will cause the ecu to go into test mode and it will pulse each injector and igntioin output. This is a great function to use to determine if you wired your outputs correctly
Old Mar 20, 2004 | 02:32 PM
Rick James
Thanks
Rotospectre
Mar 28, 2018 03:33 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
sYnth.
Aug 14, 2015 01:37 PM
