mods to turbo a nikki?
Old Mar 17, 2004 | 07:57 PM
BooStiN2BaRz's Avatar
Question mods to turbo a nikki?
ok so i have been searching and cant find someone posting what needs to be moded? sure people have done it, so how about what it took to get it done, like:jetting, turbo hat, floats..ect? come on share the know how.
Old Mar 17, 2004 | 08:15 PM
680 whp how did you do it? come on some one.... anyone?
Old Mar 17, 2004 | 08:47 PM
dirty86's Avatar
i would say the biggest thing to change in your carb would be the little flux capacitor needle they cant handle boost
Old Mar 17, 2004 | 08:49 PM
haha flux capacitor maybe i should run beer injection.:d
Old Mar 17, 2004 | 08:50 PM
FB II's Avatar
gotta fill the float pieces, seal everything tight, use special gaskets that won't blow out. no choke, mechanical secondaries, umm.stuff?
Old Mar 17, 2004 | 08:56 PM
y fill floats there rubber? i thought that only metal floats crush under boost? I just did a rebuild with rubber gaskets no paper crap, and converted to mechanical secondaries(big inprovement... but it is time to for a turbo!)
Old Mar 17, 2004 | 09:13 PM
mwatson184's Avatar
holley guy
What are the stock floats in a nikki made out of? On my holley I had to use nitrophyl floats. Brass floats crush and plastic floats crack under boost.
Marques
Old Mar 17, 2004 | 09:14 PM
bump i am going turbo next month but getting my parts sorted out now.
Old Mar 17, 2004 | 09:20 PM
ya holley even says to use nitrophyl floats for blow through in there tunning catlog.
Old Mar 17, 2004 | 09:43 PM
bump for boost
Old Mar 17, 2004 | 09:44 PM
bump for boost
Old Mar 17, 2004 | 09:45 PM
bump for boost
Old Mar 17, 2004 | 11:23 PM
O 16581 72452 5's Avatar
The infamous number guy!
You should be good up to 5psi on the stock carboretor.
Old Mar 17, 2004 | 11:38 PM
but i dont want get by, i want to build it for up too 15psi on a sp 12a.
Old Mar 18, 2004 | 01:35 AM
Gregs's Avatar
you need to contact robert from rotary shack, thats all i have to say
Old Mar 18, 2004 | 01:45 AM
Gregs's Avatar
that may be right, but the stock nikki cant push more than 155hp so it would pretty much be pointless
Old Mar 18, 2004 | 08:22 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Greg, I'm gonna have to call ya on this one, and ask just how you know that, and to please explain that to us all.
Old Mar 18, 2004 | 08:26 AM
Sterling's Avatar
Well I must suggest that you need to do some serious research if you are concidering a stock Nikki for such an application.
I must also suggest that choosing the correct carb for such an application should be one of your lesser worries at this early stage.
Old Mar 18, 2004 | 08:49 AM
i have looked in to this and found that it would probaly be easier and cheaper in the long run to spend $1500, and buy a 12a turbo from rotary shack...well put together factory turbo motor v.s. garage special...you do the math.....plus you get that cool red intake manifold.
Old Mar 18, 2004 | 09:48 AM
mwatson184's Avatar
holley guy
If you are wanting to run 15psi then good luck with the stock 12a turbo, it is garbage and you will need an upgrade. I like garage specials!
Marques
Old Mar 18, 2004 | 12:10 PM
680RWHP12A's Avatar
bump for boost
bump for boost?? LOL i like that , very original!!
e-mail me and ill serve you up a boosted nikki, good for 500 hp if you god the *****
bump that for boost
Old Mar 18, 2004 | 12:29 PM
inittab's Avatar
I read your email
bump that for boost
Per the original question...... So what exactly needs to be modded on a Nikki to "serve up" boost?
Old Mar 18, 2004 | 12:56 PM
680RWHP12A's Avatar
alot!
Old Mar 18, 2004 | 01:05 PM
inittab's Avatar
I read your email
alot!
of money?
Surely there are specific things that need to be done. What kinds of things are modded on it?
Originally posted by BooStiN2BaRz come on share the know how.
This board is all about sharing knowledge
Old Mar 18, 2004 | 01:23 PM
coldy13's Avatar
Yeah, shutup kid.
That's only when it's n/a, and it's about 140, not 155. When you go turbo with it, the flow doesn't matter nearly as much and you can get a lot more power out of it.
