spring rate on coilovers
Need advice on spring rates. I currently have 575 lb Hypercoils on the front and 325 lb on the back with Koni Yellows that are double adjustable. I have an extra set of 700 lb Hypercoils that I got for autox. I have to take the front suspension off and am considering putting the 700 lb on to see how bad they will be for street driving. Does anyone have springs this stiff on for street driving? I know they will be bad, but want to know if I will be wasting my time even trying them for street use. Opinions? Also- has anyone tried Hyperco's hydraulic spring perches?
Ron A.
Ron A.
How's your back these days?
If the shocks are valved to match the spring rates, the street ride quality can be tolerable. If not, then the ride quality will suffer substantially. But, to keep things in perspective ... a well setup auto-x car is more than likely not going to be comfortable on the street (unless your local roads are well kept and flat).
-Don
-Don
Originally posted by snub disphenoid
I believe my JICs are 9xx in front and 8xx in the rear. They are about as tolerable as my ST spring/Tokiko HP setup I previously had, although they're much more fragile.
Ronardt: I would stick with the 575 up front, which some would argue is too stiff already. I think the only thing the 700 lb spring will give you is a worse ride and more understeer.
spring rates
originally posted by redrotorR1:
There is one particular stretch of road with a compresion dip with a pothole that is tough to miss. If I do not successfully navigate around it, it feels like someone is hitting the bottom of the car with a really big sledge hammer. Otherwise ride is not too bad.
rynberg- I guess I was asking queston I already knew the answer to, but was wishing for someone to offer me some hope. Anyone want to buy some new 700 lb springs?
Ron A.
Ron A.
[For Sale] Scratch & Dent, Used, and Open-Box Sale!
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
vxturboxv
Sep 16, 2015 04:16 PM
