it still wont start
Old Mar 17, 2004 | 12:06 PM
ax350's Avatar
Newbie
it still wont start
i`ve already talked about this about 3 days ago, my 81 is getting gas air and spark yet it wont crank , it`s turning over but wont start. i`am gettint really pissed, ccan some one share some wisdom to my poor car.
Old Mar 17, 2004 | 12:53 PM
slashdawg00110's Avatar
RTFFAQ
How's compression? Does it fire if you spray carb cleaner into the carb and then try to start it?
Old Mar 17, 2004 | 05:01 PM
Junia's Avatar
Uchinanchu
when I accidently make my car not want to start I just pour a couple tsp of oil down the intake and she starts right up. smokes for about a minute and by the time shes ready to go all the smoke is gone. Someone told me once to drop some atf but I rather use regular oil since that what I'm burning already anyway.
Old Mar 17, 2004 | 11:44 PM
mcnannay's Avatar
Lean Mean Speed Thingie
i had the same thing going on with my 84 the other day, it had spark, crank, and i thought fuel. The fuel bowls were full, but no gas through the rest of the carb.
if you pour gas down the carb does it run? or sputter at least?
How are your spark plugs? see if they are covered in gas or fouled up.
if none of that helps id say compression is to blame
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
