Chassis reinforcement bars?
Old Mar 16, 2004 | 09:35 PM
O 16581 72452 5's Avatar
The infamous number guy!
I've seen these bars available for Mustangs which bolt to the seat bolts, then weld in at each end. I'm curious if these are available for the FB, i'm going back to wanting to chop my roof and need a good way to support the unibody. I'm getting my license suspended for 6 months and need things to keep me busy during this time period, i'm going to sell my Cadillac to pay my fines and should have $1,000 left over to get a motor back in my GSL-SE (sold most of the FI stuff, so it will be a carbed 12a going in it), turbocharge my SR5 Corolla (already have a Starion turbo laying around), and chop the roof from my FB to have a fun summer car.
Not that i'll get to enjoy it this summer. -_-
Old Mar 16, 2004 | 09:53 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
a good roll cage will stiffen the whole car up. i dont know how well CPracings cage will do but i know that custom ones that go from the rear to the front and have a cross beam against the firewall make one hell of a differance.
Old Mar 16, 2004 | 09:55 PM
A roll cage on a chop top? That would look a bit goofy. I'm talking about bars that would run across the bottom of the car to keep it from tacoing.
Old Mar 16, 2004 | 11:32 PM
what an ***.... haha
They are called sub-frame connectors....
just weld some bars all under there, it will be just the same......
my brother has an 88 coupe with subframe connectors on it to prevent twisting..... its just a bars that runs parrell, front to back, on either side of the car..... ghetto if you ask me.... just get some thick bar, and have at it... make a roll bar behind the seat, and add another bar to each side to make a small triangle goind forward, not so far up where you can see it though......
later
Old Mar 17, 2004 | 12:13 AM
later
I'd like it to be somewhat professional, the bars made bend up with the undercarriage and bolt to the seat bolts.
I'll look into what you suggested however, where did your brother get his bars?
Old Mar 17, 2004 | 06:48 AM
rx-7ames's Avatar
strutt tower bars should help too, shouldn't they?
Old Mar 17, 2004 | 10:56 AM
Forcus's Avatar
Well since there are full frame rails (still a unibody) going from front to back there are no subframes, per se, to connect.
I would do a full roll cage with the tie in's made to the rocker panels and the framerails. I know you don't want a roll cage but that's just what I'd do.
If you want to strengthen the unibody you could run another square tubing rail along the stock one and connect it to the rockers/frame rail. I don' t know.
Old Mar 17, 2004 | 11:58 AM
MarkPerez's Avatar
Tennis, anyone
remember we ';talked' about this before.. don't cut anything untill you brace first..... a good welder, knowing how to weld, square tubing stock, some flat steel. no bolting to where the seats bolt,,,,no.
sub-frame connectors run under the car tie the front to the rear the lenght of the firewall to right before the rear wheels. they have to be even, large enough diameter to be ridgid. then brace right behind the seats
connecting port to starboard again large enough diameter stock to be ridgid...... take a welding class and NO FENCE POST's !!!
Old Mar 17, 2004 | 12:00 PM
MarkPerez's Avatar
Tennis, anyone
Old Mar 17, 2004 | 12:09 PM
cosmicbang's Avatar
You need to reinforce the windshield frame, and also cross-brace under the car.
Old Mar 17, 2004 | 12:29 PM
I remember what was discussed and now know how to properly do this project, i know the materials to buy, etc. I now need to know where to buy these materials.
A friend of mine purchased a good welder that i will have access to.
Not a definate plan, but if i have money left over after paying fines and turbocharging my SR5, i'd still like to do this.
Where am i going to be able to find ~80 inches of flat steel bars, it's not like they're as easy to find as fence posts.
Old Mar 17, 2004 | 12:31 PM
A strut tower brace won't keep my car from folding down the center.
Old Mar 17, 2004 | 05:32 PM
Is there any pictures of Roll bars that do a good job of bracing the car? I would love to see where its connected!
Old Mar 17, 2004 | 05:39 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
distant shot but u get idea. we made it as stiff yet light as possible. it's very easy to go ape adding tubes everywhere that marginally stiffen the car yet still add weight and cost.
Old Mar 17, 2004 | 05:56 PM
yea that looks good.........but i was kind of looking for specific spots of where to put my cage....
Old Mar 17, 2004 | 06:16 PM
nutjob check out www.cpracing.ca they have prebuilt cages.
Old Mar 17, 2004 | 09:09 PM
MarkPerez's Avatar
Tennis, anyone
Hey drivefast7. i was in the same row at sevenstock,
but i didn't look under your racecar is it still a uni body
or a semi-rolling chasis,, no sub frame connections ?
Old Mar 17, 2004 | 10:39 PM
BooStiN2BaRz's Avatar
maybe you should seem weld the car it would stiffin it up and you wouldnt have to buy any bars( just spools for the welder) just a thought.
Old Mar 17, 2004 | 10:49 PM
DriveFast7's Avatar
Uni-body Mark.
Didn't touch the sub-frames. Don't need to really. It is pretty stiff as-is. I talked to the welder about extending bars from front strut towers down to frame and connecting front frame rails together in front of the engine but we all agreed it's unnecessary for 205RWHP on 10" rear slicks and just adding more weight and getting in the way.
We did a trick triangulated front strut tower brace. It's not in the attached picture but you can see the brackets and get the ideaer.
Old Mar 17, 2004 | 11:02 PM
DriveFast7's Avatar
during install
