transmission
Old Mar 15, 2004 | 04:20 PM
dirty86's Avatar
Unhappy transmission
well I CANT GET IT up there
i have it all aligned now i need to wait for my father to come here to help me
i had it up there i just couldnt get er in
so i droped it back down
i have clutch all aligned and every thing
the problem with my transmision was the shaft bearing it was totaly disintegrated
so when i would put in the clutch the transmision would still spin so i couldnt shift easlily
Old Mar 15, 2004 | 10:33 PM
84stock's Avatar
Didyou replace the "input" shaft bearing. If so, how easy was it once the tranny was out (did it pop out the front easily after removing the cover?)
Old Mar 16, 2004 | 07:00 AM
Rx7carl's Avatar
Airflow is my life
Sometimes you have to turn the trans slightly to get the input splines to mate with the clutch. Also make sure the 2 alignment lugs on the engine and holes in the trans are clean.
MILOS7
Oct 9, 2015 02:19 AM
rxlevi7
Sep 26, 2015 07:28 AM
