460 rwhp at 17psi ( 1.15 bar ) TURBO ????
Old Mar 15, 2004 | 09:25 AM
sevenin7's Avatar
Guys, i prepare a new engine with :
3mm hurley racing apex seals
street porting
Greddy fmic
koyo rad
hks twin power
magnecor 16 bit wires
3 inch full exh
sard 280 lt/h in tank
sard fuel reg
850 prim
1300 sec
PFC + datallog
avcr boost contoller
etc....
As i know with (850+1300cc) = 4300cc total flow and 85% duty cycle can produce 460hp at the wheels. I would like to know which is the ideal turbo ( efficiency )to put down this power with 17 psi ( 1,15 bar of boost ) ?
Thanks.
Old Mar 15, 2004 | 11:45 AM
Broken09's Avatar
I am becoming...
I believe you'd be able to achieve that power or close to it with a T-78 or GT40r. But it depends on what you mean by Ideal.
Old Mar 15, 2004 | 01:19 PM
Infini IV's Avatar
Microtech Tuning!
T04R or PT67 probably?
Old Mar 15, 2004 | 01:32 PM
racer1's Avatar
flying apex seal
sevenin if you have the money go for the new Apexi AX75F92 or a T51R-KAI, they will give you those numbers although i don't know how laggy they will be. Otherwise a well tuned T78 with a bit more boost.
Old Mar 15, 2004 | 01:45 PM
$150FC's Avatar
Currently Winning
maybe a T78 with a 88mm GT40R compressor wheel? some guys have used this, they are happy with it apparently.
Old Mar 15, 2004 | 04:27 PM
Zero R's Avatar
Just in time to die
By the time you do this you could just go with the straight 40R and have a easier to get parts for turbo.
Old Mar 15, 2004 | 05:15 PM
Jason's Avatar
The one
Someone needs to cough up a GT40 dyno graph and backup the "its as good as the T-78" claims.
Old Mar 15, 2004 | 05:53 PM
sevenin7's Avatar
Jason , tell me your opinion about the turbo kit (460rwhp with 1.15 bar )!
Old Mar 17, 2004 | 02:13 PM
sevenin7's Avatar
Jason !!!!!!!
Old Mar 17, 2004 | 02:17 PM
fastcarfreak's Avatar
3rd motors a charm I hope
t78 is what you want, 400 plus is right around its efficiancy. smaller turbos you are going to have to spin the **** out of and will probably wear out faster, not to mention create more heat. Bigger turbos will be more laggy.
Old Mar 17, 2004 | 02:40 PM
Jason's Avatar
The one
We have seen those numbers out of the T-78, but thats on a large port. Its doable
Jason
Old Mar 17, 2004 | 03:52 PM
sevenin7's Avatar
Jason , do you suggest me the T-78 , or something else ?
Old Mar 17, 2004 | 04:42 PM
Poweraxel's Avatar
soon, soon ...the GT40 is farily new and the GT40R (Ball bearing) are not even in full production yet... im sure in do time people will have GT40/GT40R dynos
Old Mar 17, 2004 | 05:33 PM
Jason's Avatar
The one
Depends on how much power and response you want. The T-78 is a great setup and if I didnt think so it wouldnt be on my car
If you are looking for a complete setup the XS T04S kit is the most complete. Makes good HP and comes with intercooler piping and blow off valve. Best bang for the buck.
Jason
Old Mar 17, 2004 | 07:26 PM
WaachBack's Avatar
Finally Knows
If you had a Greddy intercooler, wouldnt the t-78 kit be more complete?
Old Mar 17, 2004 | 08:55 PM
Jason's Avatar
The one
Yea then they would mate up. The Greddy doesnt come with the BOV.
Jason
Old Mar 17, 2004 | 09:16 PM
ZoomZoom's Avatar
SEMI-PRO
At that boost level and your HP goal you really need to go large on the turbo. Even then your not garrenteed 460 at 17 psi. Thats a LOAD of power also. Expect to have some fierce mods for the driveline.
Old Mar 18, 2004 | 03:09 PM
BoostedRex's Avatar
NorCal 7's Co-founder
TO4R, GT40R, T78, T-51R Kai or SPL, T88, PT67. You have several choices that are capable of what you are looking for. Alot of it will come down to your tuning and how much lag you are willing to have. Although shooting for numbers like that, lag shouldn't be that much of a consideration for you.
Jason, rx7tt95 posted dyno graphs of his standard bearing GT4082 in this forum. He put down 410 at 15psi and that was with a/f's in the 10's from what I remember. Just remember that's the smaller of the GT40 compressor wheels too. Just wanted to point that out since you asked about dyno graphs. Laterz.
Zach
Old Mar 18, 2004 | 03:29 PM
sevenin7's Avatar
Are BB turbos less reliable than standard , and it is a upsurd amount of money to rebuild them ?
Old Mar 20, 2004 | 08:17 PM
yogi's Avatar
A turbonettics T66 spec'd right will do 500RWHP (dynojet) at 18PSI and will spool only 2-300 rpm slower than a GT3540
Old Mar 20, 2004 | 10:06 PM
artguy's Avatar
WTB** Very Low Miles 94-95
jason your car is looking great man. Im jealous.
Old Mar 20, 2004 | 11:00 PM
mmonaco's Avatar
Part out my Car
You seem to be mis-leading him along the lines of tuning. Your comment "He put down 410 at 15psi and that was with a/f's in the 10's from what I remember" leads him to believe he can make alot more power with higher a/r ratios(11.0's), yet raising A/F ratio only give a minimal increase in HP gains, where most of the extra power is made is in timing i.e. proper timing, zeroing split, minimal split ect. Enough said just want to set that straight.
Old May 14, 2004 | 03:58 AM
ismaelruiz's Avatar
I made 453 rwhp with a Turbonetics 62-1 with .96 on center exhaust housing and P trim at 16-17 psi. It is a very reliable turbo. The car is a daily driven FC.
Old May 14, 2004 | 04:33 PM
Infini IV's Avatar
Microtech Tuning!
Do you happen to have a dyno sheet of that? Just curious at the powerband.
Old May 14, 2004 | 05:49 PM
Asleep's Avatar
7 Rx-7s since 1980
Anyone have a Dynojet graph of 460RWHP at <=17psi on pump gas?
