cant start my 85 rx
Old Mar 15, 2004 | 12:49 AM
immanuel__7's Avatar
cant start my 85 rx
hi i tryed to start this car before i payed for it, so i turned the key over and it just would not start even if i put gas down the carb, so i just payed for it and parked it for the winter, now i want start it so i dumped the 3 year old gas and put new gas in drained the fuel line to the carb, and installed new spark plugs, when i try to start it the RPM reads 1000-2000 but as sone as i put gas down the card it turns 3000 ish, but i never hear it start it just turns faster, some one toled me thers no compretion and that the readth valve is stuck open/craked or shattered, thats Y its not running? dose the sound like its the prob? o and when i did a compretion test with a regular guage it was reading 0 psi so, i think thats my prob how do i get to that valve?
now keep in mind that i did the compretion test using the traling #1 apex (top hole) and not the botem one.
and how should i do the ATF thing? if its not carboned locked? my dad says i should atf it so that the seals will free them selfs thats Y it has no compretion?
Old Mar 15, 2004 | 01:48 AM
hornbm's Avatar
FD > FB > FC
U gotta type clearer, your cranking at 1000-2000 RPM?!?!
Old Mar 15, 2004 | 02:46 AM
mazdaverx713b's Avatar
Have RX-7, will restore
yes, if the apex seals are stuck you will get no compression. atf will flush them free. compression will be restored if your problem is stuck seals. it may take 2 times to completely free the apex seals.
Old Mar 16, 2004 | 09:53 AM
thanks guys that should help me out I hope
Old Mar 17, 2004 | 02:17 AM
please keep us updated on your situation. hopefully we can help you get your problem squared away
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
